Author: Subject: which sierras...
suparuss
posted on 23/9/03 at 09:22 PM Reply With Quote
which sierras...
...had rear calipers?? was at me local polar ford parts counter asking for some slider diaphragm sealamajigs but cos i got me parts from locostparts.co.uk i dont know what year car it is or the model?
Russ.
posted on 23/9/03 at 09:50 PM Reply With Quote
its been said that GLS have the disc brakes, though it may also be to do with age. thats all i know officer!
Stu16v
posted on 23/9/03 at 10:01 PM Reply With Quote
The 'XR' series Sierras all had disc brakes....
Donners90
posted on 23/9/03 at 10:17 PM Reply With Quote
I got a set of calipers only, so didn't know the age of the car, but from searching through the Ford TIS (technical information service) the part number (85GB 2M004 AB) for the repair kit doesn't change for all models fitted with rear discs, so the year may not be too relevant.
Are you after the caliper overhaul (seal) kit? Ford don't seem to sell just the seals for the rear calipers, they make you buy the piston too (+/-£60 a side!!). If you're after the seals then talk to either Mike Collins, or Darrel at Brakes International, as they supply just the seal kits (see below for email sent to me) I said the vehicle was an '87 and the seals fit perfectly - I may have jut got lucky though!:
"Yes we do the seal kits which contain all the seals within the caliper and no piston and yes we do mail order. The seal kits are £8.94 per side plus vat. Delivery by ups next day £6.00 plus vat
If you would like any more information please ring me on 01254 695695
Mike Collins."
email: brakes3@zen.co.uk
They should still have some in stock and the bits came the next day. Very helpful. They also had a deal on rear pads £6.95 a set!! Web Offer. www.brakesint.co.uk
Hope this helps
Donners
suparuss
posted on 24/9/03 at 04:00 PM Reply With Quote
did that come with the lttle boots for the slider thing that holds on the outside pad?
just tried polar again and their system says it is no longer available.
ill email that collin guy and see if they are available seperate, cos my piston seals are all sparkly and new already.
cheers,
Russ.
Donners90
posted on 24/9/03 at 05:02 PM Reply With Quote
Russ,
The rear caliper kits from Brakes International came with the following:
Cylinder seal
Interior piston seal
Cylinder seal (handbrake mechanism)
Piston dust boot
2x Slider boots
Slider grease
and rubber bleed nipple cover.
If you are just after the boots then the Ford part number for a boot kit is 83BB 2L526 AA. However this, as you found out, may be the part that's no longer available.
Good luck
Donners
suparuss
posted on 24/9/03 at 06:30 PM Reply With Quote
cheers, thats something to go on, i might be able to find an equivelant motaquip part or something. ill try my local snell peugeot parts counter tomorrow (sounds daft i know, but when i wanted some sierra driveshaft gaiters, they had 3 in stock, while polar ford had to order em, and snell were cheaper too!?!?!)
Thanks,
Russ.
andyps
posted on 25/9/03 at 08:45 AM Reply With Quote
I've got a '92 GLS sierra and it has rear disks.
jcduroc
posted on 25/9/03 at 05:47 PM Reply With Quote
ATT: I found an XR4i (in Portugal, made in belgium) that had rear drums. That's why I didn't buy it.
JCM
blueshift
posted on 25/9/03 at 06:17 PM Reply With Quote
afaik all the 4x4 ones have rear discs. our ghia 4x4 does.
accident
posted on 28/9/03 at 12:14 AM Reply With Quote
all the 2.8 xr4i had drums,big drums that actually worked better than the shoddy disks.
however the rear caliper was the same part on all the non vented rear braked fords regardles of disk size(they had different hangars)also the same caliper also showed up on rear disk braked golfs.
jcduroc
posted on 28/9/03 at 01:51 PM Reply With Quote
Originally posted by accident
... however the rear caliper was the same part on all the non vented rear braked fords regardles of disk size(they had different hangars)also the same caliper also showed up on rear disk braked golfs.
You mean the caliper brand and type is the same in those Ford's and Golf's?
Do you know which ref#?
JCM
