Author: Subject: Securing brake lines at unions...
tegwin
posted on 29/10/07 at 03:03 PM Reply With Quote
What is the SVA approved safe method of mounting brake lines where they join? (Im sure someone on here mentioned that they had failed due to their mounts being wrong)
I currently have female ridig pipes and male flexi pipes. The male is pushed through a hole in the bracket and the female is then screwed over the male... However this does not clamp the pipes firmly in the bracket...
And NO...im not planning to use tampons
[Edited on 29/10/07 by tegwin] Rescued attachment Brake union.JPG
mookaloid
posted on 29/10/07 at 03:19 PM Reply With Quote
you need a slim nut to secure the male bit to the bracket before connecting the female brake pipe nut to it.
Mark
iank
posted on 29/10/07 at 03:21 PM Reply With Quote
You'll be wanting a bulkhead fitting, either in the flexihose like these mini ones:
http://www.minispares.com/Product.aspx?pid=34809
Or Automec do a bulkhead fitting. HU106 which I think allows M10 1mm fittings either side, but there's no picture on their website I could find
Anonymous
posted on 29/10/07 at 03:24 PM Reply With Quote
I had male bulkhead fittings - same as ordinary male ends, but with a longer threaded part. This fitting was secured with a slim M10 nut, leaving sufficient thread for the female fitting that joined to it.
bigrich
posted on 29/10/07 at 04:52 PM Reply With Quote
thin nuts used on side panel joint then a reinforcement disc fitted to stop panel flex.
different position same principal
tegwin
posted on 29/10/07 at 05:36 PM Reply With Quote
Ok, looks like all im missing are the slim nuts...
Standard ford hoses are 10x1.0mm arnt they?
And where can I get the nuts? Chears.
ed_crouch
posted on 29/10/07 at 06:45 PM Reply With Quote
Careful!!
quite a lot of them are 3/8"UNF.
Ed.
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
