Author: Subject: Track Rod Ends/Balljoints
Ben_Copeland
posted on 26/9/03 at 07:34 PM Reply With Quote
Which ends/balljoint should i be using to connect an Escort Rack to a Sierra Hub ??
I've tried escort trackrod end, but it's too small to fit the hub
I've tried sierra trackrod end, but the thread isn't the same....
So whats the answer please people, cos i can't seem to find it anywhere on here
posted on 26/9/03 at 08:37 PM Reply With Quote
maybe make an extension like thing that screws onto the escort size thread and has sierra size thread at the other end. Did u need an extension as well or was it previously the correct length?
Ben_Copeland
posted on 26/9/03 at 08:42 PM Reply With Quote
No extension is needed.... it's a standard rack.....
I know it's been done, just wish the person knew what balljoints had been used
Someone must know what to use !
cosworth
posted on 26/9/03 at 09:19 PM Reply With Quote
sierra track rod ends will fit onto escort track rods
posted on 26/9/03 at 10:45 PM Reply With Quote
It has to be a Mk2 Escort rack or you will not have the metric track rod ends you need to suit the hubs.
yours, Pete.
Ben_Copeland
posted on 27/9/03 at 07:55 AM Reply With Quote
It is a Mk1 Escort Rack.............
So what can i do ?? except change the rack
posted on 27/9/03 at 08:39 AM Reply With Quote
Get your money out. You should get an exchange rack for a decent price.
yours, Pete.
Ben_Copeland
posted on 27/9/03 at 05:06 PM Reply With Quote
bo88ocks
Northy
posted on 27/9/03 at 05:13 PM Reply With Quote
New track rods? Burtons sell them
Graham
Ben_Copeland
posted on 27/9/03 at 05:15 PM Reply With Quote
Yeah, i really didn't want to start spending money on stuff like that, just wanted a set of ends that would work
givemethebighammer
posted on 28/9/03 at 09:26 PM Reply With Quote
have you tried a set of cortina track rod ends ? I know later (mk4 and 5) are metric M14 2.0 threads maybe earlier ones are not ?
That said an exchange rack will only set you back £30 ish
[Edited on 28/9/03 by givemethebighammer]
Northy
posted on 29/9/03 at 06:49 AM Reply With Quote
New Tie rods in Burtonns £7.62 each
Cheeper than an exchange rack.
Graham
Ben_Copeland
posted on 29/9/03 at 07:03 AM Reply With Quote
The older cortina is the same size as the escort ones..... hence why escort ones fit cortina hubs, but alas i have sierra hubs
Cheers Northy, i'll have a look, if it's goign to be cheaper.........
