Author: Subject: Help..... Brakes / M/C,etc
Ben_Copeland
posted on 2/10/03 at 08:22 AM Reply With Quote
Right.... I've got a Mk1 Escort Pedal Box(modified now) in the car, but the mk1 Master Cylinder is no good for SVA.
So please can someone suggest a Master Cylinder.... I've heard a Sierra one (92mm between holes???) would like a M/C with 4 outlets tho
Also, where can i get a bias adjuster from (car in scrappy) I've heard Fiat Uno ?? Any info on year/models of different cars?!
Is the connection between master cylinder and pedal easy enough ?
Sorry for all the questions, I've looked through the previous posts and its a little confusing with all different info all over the place and no one seems to use the escort box ?!?!?!
ned
posted on 2/10/03 at 09:00 AM Reply With Quote
not a scrappy, but rally design do an adjust bar for £20-30. I have a sierra master cylinder if you want it? or rally design sell loads of girling/wilwwod ones, one of which must be compatible!
Ned.
beware, I've got yellow skin
Ben_Copeland
posted on 2/10/03 at 09:06 AM Reply With Quote
Cheers Ned. I'll probably have it off you
Was hoping to get one from breakers.... so i'll hold up on calling Rally design just yet lol
bob
posted on 2/10/03 at 11:39 AM Reply With Quote
FIAT UNO valve.
Ben they are all the same AFAIK.
Ben_Copeland
posted on 2/10/03 at 01:49 PM Reply With Quote
Ta Bob..... just have to find a Fiat Uno now lol
Any idea where in the car they are mounted ???
[Edited on 2/10/03 by Ben_Copeland]
givemethebighammer
posted on 2/10/03 at 03:42 PM Reply With Quote
Don't bother trying to rip one out of the car. They cost £15 from GGB in Bradford no. is 01274733727
If you really want to try its under back seat and near back axle. But expect a dirty rusty mess that you can't guarantee to work properly. It's FIAT after all !!
Ben_Copeland
posted on 2/10/03 at 04:38 PM Reply With Quote
Thanks !
I'll keep that in mind
Dick Axtell
posted on 2/10/03 at 06:33 PM Reply With Quote
Also, where can i get a bias adjuster from?
Ben - If you want a tandem mcyl (as opposed to the binocular twin mcyl set-up) you could look at a non-servo Mk1 Fiesta. This would provide you with the necessary clevis + input rod to connect up to the pedal.
Bias adjuster - Mk2/3 Fiesta had/has 2 PCRV's screwed into the mcyl.
(PCRV = pressure concious reducing valve)
One of these fitted into the line to the rear brakes will limit the pressure rise rate, relative to that at the fronts.
Ben_Copeland
posted on 2/10/03 at 06:38 PM Reply With Quote
Would a mk1 non-servo m/c have the electronic level thing ???
Gonna go for a fiat bias adjuster !
Dick Axtell
posted on 2/10/03 at 07:46 PM Reply With Quote
FLWI
EEEEElectronic!!!! Do me a favour - it's a simple float-operated contact, which closes a normally-open switch, to light the indicator lamp. And yes, non-servo mcyls had these devices as well.
Jap mcyls often have the solid-state type, with a float-mounted magnet to operate a reed-switch embedded in a suitable reservoir component.
[Edited on 2/10/03 by Dick Axtell]
Ben_Copeland
posted on 2/10/03 at 08:01 PM Reply With Quote
you know what i meant
A level indicator that isn't looking at the level on the reserviour by eye !!!!
