deanwilson
| posted on 27/11/07 at 07:22 PM |
nissan sr20det diff
hi there i am building a nissan powerd locost and i have come to make the diff area and one of the drive shafts are shorter then the other and if i
get the drive shafts equal on both sides the diff anit in then middle then has any one used an s14 diff and what have they done about th e problem i
throught about making a spacer where thr drive shaft bolts to the diff would this work
Paul (Notts)
| posted on 27/11/07 at 07:34 PM |
Dont know about the nissan diff and drive shafts BUT the sierra diff has one driveshaft shorter than the other.
Paul
Paul (Notts)
| posted on 27/11/07 at 07:47 PM |
this is how it works with the sierra diff
Humbug
| posted on 27/11/07 at 08:32 PM |
Jasper's got a Nissan engine... not sure what diff, though.
graememk
| posted on 27/11/07 at 08:34 PM |
i'm using a nissan engine and box but using ford diff
James
| posted on 28/11/07 at 02:48 AM |
Sierra.
James
- Muhammad Ali
deanwilson
| posted on 28/11/07 at 09:12 AM |
how can i get round the problem then as the pic of the sieera diff is the same as mine
Liam
| posted on 29/11/07 at 07:01 PM |
What problem?
The shafts are different lengths so that the diff is in the middle.
Or are you saying your diff is like the sierra's but your shafts are equal length?
Liam
deanwilson
| posted on 30/11/07 at 06:36 PM |
na my drive shafts are different lengths but when i get the diff in the middle the prop dont go don the middle
| posted on 1/12/07 at 12:59 AM |
Not sure I understood that?
You need to align the diff so the prop flange is (more or less) in the middle of the transmission tunnel. Because of the way a diff is constructed,
this will mean the diff housing is offset to one side, which is why one driveshaft needs to be longer than the other.
Ivan
| posted on 1/12/07 at 07:28 AM |
I would look at the nissan where the diff came from and then set it up that way. i.e. - does the Nissan have the prop flange in the centre of the car
or off to one side.
It's fairly normal to have your prop flange an inch or two to one side as universal joints work best if not in a straight line - nearly all
solid axles are that way.
deanwilson
| posted on 1/12/07 at 08:27 PM |
i solved the problem now it does fit it fitted from the begining the problem was that i took the drive shafts off and then but them on the wrong side
so it would nether of lined up so thanks for all your help from the begin it was me being stupied
