Mr Whippy
| posted on 30/11/07 at 09:58 PM |
Ball joints for wishbone joints
God I know this has been asked before and I did do a search with no luck.
I have to make new wishbones and their much larger than the ones on a 7, I thought I could use a heap of transit ball joints (16 in total) instead of
the plastic bushes and weld in threaded sleeves into the ends of the wishbones.
I figure this will let me adjust the whole suspension till it works (since it will be all wrong anyway), I had thought of rose joints but their not
cheap and don't seem to last very long on the road. What do you think? Is this -
a) another stupid idea
b) an expensive stupid idea
c) amazingly worth a try
[Edited on 30/11/07 by Mr Whippy]
| posted on 30/11/07 at 10:03 PM |
Probably better to make the eyes of the wishbone adjustable and use plastic bushes with correct size crush tubes?
oadamo
| posted on 30/11/07 at 10:11 PM |
130177142569 these any good of the bay very cheap with sizes. iam gonna use them for a project iam doing at the mo.
adam
RazMan
| posted on 30/11/07 at 10:53 PM |
As Rusty said, I would go for plastic bushes as they will be quieter (less road noise) and are designed for the job. Are Transit ball joints ok for
the different loading & stresses?
Raz
Mansfield
| posted on 30/11/07 at 11:11 PM |
Mr Whippy, you are one crazy dude.
Mr Whippy
| posted on 30/11/07 at 11:23 PM |
Hmm good points, on my 7 rear wishbone the plastic joint is adjustable but it's large and clumsy (hideous) and not something to grace this new
car. I just feel the ball joint looks more appropriate.
I think the transit ones are up to the job and I think I'm wasting my time worrying about noise when I'm sitting here...
D Beddows
| posted on 1/12/07 at 12:21 AM |
I suppose suggesting engineering it properly is out of the question?
jwallbank
posted on 1/12/07 at 09:43 AM |
Ball Joints for wishbones
It's always worth exploring alternatives, but here's my answers to your questions plus some additional comments:
a) not necessarily a stupid idea - most innovations start life as a stupid idea!
b) Quite cheap to do, I think you can buy the joints for £2 - £3 or maybe cheaper for a job lot!
c) whether it's worth a try I'm not sure, that's got to be your call. How much time have you got and if it fails does it blow you
budget to rectify it.
Alternatives you might consider:
1. Rose joints - Mc Gill sell the decent teflon/kevlar lined ones very cheap on ebay.
2. If you stick with the plastic type bushes you could mount the eye tube onto a threaded bar and then into inserts on the end of the tube and use
that to get your adjustment. ChrisG's new book uses this for the adjustment on the rear IRS upright top joint. This gets the adjustment without
lots of cost. Seem to remember reading that they use similar ones on some 4x4's - Jeeps I think.
3. Also if you are using plastic bushes take a look at Wisbech Engineering - they sell the Eurethane bush halves for £0.55 each. They also sell the
Crush & Eye tubes but you can make these yourself to keep the costs down. The eye tubes are exactly the same dimensions as standard steam pipe - 1
1/4" dia I think!
Finally, back to your original idea, Autograss racers have been using Transit or Sherpa Track Rod Ends for the top and bottom joints for years on
single seaters with the likes of V8's in the back and you don't see any fall apart except in a very hard coming together! (Although these
days most have converted to rose joints). So if they will stand up to use on the outer joints in those conditions I'm sure they would be fine on
the inners also.
John W
Mr Whippy
| posted on 1/12/07 at 01:06 PM |
thanks very much John
I'm very impressed with the Rose joints from Mc Gill.
cheers
[Edited on 1/12/07 by Mr Whippy]
RazMan
| posted on 1/12/07 at 01:28 PM |
Get the best you can afford - my first set only lasted 5k miles even though they were Teflon lined. Budget for around £25 each and you won't go
far wrong.
Raz
Mr Whippy
| posted on 1/12/07 at 10:48 PM |
£25 each, cripes. Which ones are using now RazMan?
RazMan
| posted on 1/12/07 at 11:45 PM |
A lot of people buy cheap unlined rod ends for £3 or 4 in 1/2" or bronze lined for £10 and they are not really very good. They will not last
five minutes on the road.
Quality rod ends are expensive - but will do the job well and last much longer. Mine are still ok after 8k miles so I don't expect to replace
them again for a while.
Go for National Rod End TSMX8T for £22.50 ea or for the ultimate in durability NMB ART8ECR would be £56ea.
Drop Nick Skidmore a line to order them if you can't find them.
Raz
| posted on 2/12/07 at 09:04 AM |
Unfortunately rod ends will always have a considerably shorter life on a road car than OEM type ball joints simply because there is no mechanism to
compensate for wear.
[Edited on 2/12/07 by MikeRJ]
