locoboy
posted on 6/10/03 at 08:44 AM |
tyre circumferance
Hi all,
Can anyone point me in the direction of a site that has a spreadsheet for working out different nominal tyre circumferances based on imputting the
tyse size, eg 205/55/15
Locoboy
Mk-Ninja
posted on 6/10/03 at 09:08 AM |
Col
Go to the Toyo website, there is a tyre calculator there.
If you want a spreadsheat for working out gearing once you have your tyres let me know.
Gordon
I'm sure I've got one, just don't know where I've put it
locoboy
posted on 6/10/03 at 09:22 AM |
Gordon,
Cheers for the link,
I have the tyres and everything, i have had my car on the road for the last 3 yrs and am considering a BEC conversion and need to fiddle with diff
ratios and gearing etc to make sure i am not going to red line it at 50mph in top or anything stupid, can you mail me the spreadsheet?
have U2U'd my email.
Locoboy
jonti
I'm sure soemone will ridicule my maths but and I dunno 'bout a spreadsheet but isn't it as follows:-
If total diameter of wheel is A + 2B
Where A = rim size and B = profile
For a 205/55 X 15 boot
A= 15 x 25.1 in mm
B= Profile ie height of tyre above rim is 55% of 205mm = 112.75
Therefore total D in mm = (15 X 25.1) + ( 2X 112.75 ) = 602
Using C = 3.141 x D
Ergo C = 602 x 3.141 = 1.890mm
Substitute other sizes in the equation to suite
I THINK !
Or you could use the spreadsheet suggested by Ninja !!!
[Edited on 6/10/03 by jonti]
OFROK
posted on 6/10/03 at 09:49 AM |
I measured tyres using string and tape method then used a formula I found to work out the speed at different revs in all 5 gears.
Circumference in feet x 60 xRPM divided by 5280 x gear ratio x diff ratio.
I used it to calibrate the speedo for sva and it worked for that.
yours, Pete.
locoboy
posted on 6/10/03 at 10:26 AM |
Cheers pete,
i dont know what engine i want t go with yet so i dont know the output ratio for each gear yet, i have a 4 speed g box on my pinto at present, anyone
got a clue what ratio these will be so i can run the exercise on the current set up i have?
Locoboy
mackie
posted on 6/10/03 at 10:44 AM |
Quaife have a nice calculator program you can download from their site, it even has a drop down for common tyres sizes. Simply pop in your ratios and
rev limit and click the button and it tells you top speed in each gear and rpms at various speeds in top.
http://www.quaife.co.uk/downloads/QSpeedCalc.exe
For tyre size calculations:
http://www.miata.net/garage/tirecalc.html
[Edited on 6/10/03 by mackie]
MK7
posted on 6/10/03 at 05:34 PM |
try these, (If I can make the attachments)
Michelin provided a table of tyre sizes, I added a column of circumference. I then used this information in my own excel spreadsheet to calculate
speed in different gears at a set RPM and RPM's at a given speed and gear
MK7
posted on 6/10/03 at 05:35 PM |
here's the tyre details
Mark Allanson
posted on 6/10/03 at 06:28 PM |
Here is one I made earlier that does everything
andyd
posted on 6/10/03 at 10:11 PM |
Mine's more colourful!
