xico_ze54
| posted on 12/12/07 at 03:23 PM |
U joints - again
someone can tell me why Land Rovers have the front prop shaft with the U-joints out of phase, not paralel one to another, but with a
'strange' angle?
bonzoronnie
posted on 12/12/07 at 03:28 PM |
UJ'S
Probably due to the huge amount of axle articulation.
Quite common on most 4X4's
Ronnie
| posted on 12/12/07 at 03:31 PM |
'strange' angle?
Because some grockle has had it in bits and not but the splined joint back in the correct angular position.
| posted on 12/12/07 at 03:32 PM |
Splined joint
Mr Whippy
| posted on 12/12/07 at 03:35 PM |
yeah done wrong
| posted on 12/12/07 at 03:56 PM |
which land rover?
series should be in phase; I belive the defenders are "out" by a bit, done to stop vibrations
Mr Whippy
| posted on 12/12/07 at 04:01 PM |
which land rover?
aha so it was you!
xico_ze54
| posted on 12/12/07 at 04:32 PM |
which land rover?
I mean a Defender 110 TD5. the prop is mounted on its original position.
[Edited on 12/12/07 by xico_ze54]
