locoboy
posted on 9/10/03 at 07:58 AM |
Granny Diff ID help req
I have Got the ID code off the granada diff, anyone help with finding out the ratio?
85GG HB
4A 8E02 0056
means bugger all to me.
Locoboy
stephen_gusterson
posted on 9/10/03 at 09:31 AM |
do you know what model it came from - engine size and trim level?
I have a ford owner manual that lists the typical ratios fitted, which might narrow it down a bit.....
I think I may have posted a scan of it at some time - if you want to search the site for it. I dont post that much, it should be easy to find
atb
steve
locoboy
posted on 9/10/03 at 09:45 AM |
dont post that much my hairy arse!
It was a 2.9 Scorpio, E Reg,
Tried a search but cant find anything
Locoboy
locoboy
posted on 9/10/03 at 11:48 AM |
Steve,
Found your post, thanks.
is the tab on the diff supposed to state the ratio or just give you a code to reference against a ford list of ratios?
[Edited on 9/10/03 by colmaccoll]
Locoboy
stephen_gusterson
posted on 9/10/03 at 12:55 PM |
bu$$er knows!
Where is the tab located? I can try and grovel under mine and read off the letters and see if we can make any sense by comparing if you
like.......mine is a 2.4 manual diff - I have assumed its a 2.62 (2.64?) unit...
atb
steve
locoboy
posted on 9/10/03 at 01:03 PM |
Steve,
looking from the rear of the diff, its on the upper left hand torx backplate bolt.
I assumed it woud have the ratio on it. From you scanned i just assumed it would be a 3.62, but maybe not!.
Locoboy
ChrisW
posted on 9/10/03 at 05:16 PM |
I have a list at home... u2u me a reminder if I forget to look
Chris
My gaff my rules
stephen_gusterson
posted on 9/10/03 at 09:35 PM |
85GG HB
4A 8E02 0056
With a wire brush, a rag, and some wd40 I managed to grovel and read some markings with a bright torch.
(Didnt clean up my diff - its well hidden!)
I got a few more, similar, in some cases just misread but similar, numbers......
8566 HB 364
AA (CANT READ NEXT GROUP) 0956
The 9's g's and 6's might be a misread by you or me, and you are missing a group of numbers, but they look similar....
The bit thats REALLY INTERESTING
is the last group of numbers on the to line - 364. My ford list gives the ratio as 3.64. Nice coincidence, or the diff ratio methinks.
The 2.4, 2.8 and 2.9 non 4x4 all ran this ratio.
You need to check for your missing numbers - I bet they are 364
hope that helped!
atb
steve
locoboy
posted on 10/10/03 at 08:06 AM |
Steve,
I dont think i have got any missing numbers it was taken off the diff and cleaned up with a wire brush in a bench mounted grinder, its all pretty
clear.
Locoboy
stephen_gusterson
posted on 10/10/03 at 09:29 AM |
the 364 was in the top right of the tag
you could always physically turn the input flange and count how many times its needed to turn the output one rotation...
atb
steve
[Edited on 10/10/03 by stephen_gusterson]
ChrisW
posted on 10/10/03 at 02:59 PM |
Colin
My book doesn't list an 'HB' but it may be because it is a 7.5" diff as fitted to some of the Granadas and I'm pretty
sure this list is the 7" ones only. Measure across the mounting faces which will either be 7" or 7.5".
Anyway, the list I have is as follows:
85GG 4006 DC --- 3.97
85GG 4006 BC --- 3.62
85GG 4006 AC --- 3.38
85GG 4006 FB --- 3.36
87BG 4006 GB --- 3.14
86GG 4006 AAA --- 3.92 LSD
V87BB 4006 BAA --- 3.62 LSD
V87BG 4006 CAA --- 3.38 LSD
85GG 4006 AAA --- 3.36 LSD
Sorry to get your hopes up!
Chris
My gaff my rules
