New Topic New Reply
Author: Subject: scuttle
phil
posted on 17/6/02 at 09:47 PM Reply With Quote
scuttle
Hi all
can anybody fill in the missing pieces in "the book" for scuttle making. It does not make much sense, ive made the bottom rail , front loop and rear plate but then it says cut a piece of 1" box to fit and weld in place.( where to and where at???)
Or is there a special edition of the book for thick cumbrians,
any ideas welcome
regards phil.....
paulf
posted on 17/6/02 at 10:12 PM Reply With Quote
I think you are reffering to the bit that forms the bottom rail of the dash mounting and supports the steering column in the book design.
I used a bit of 25mm round tube and supported the column from the lower rail.I would not make a steel scuttle if i was to make another one,i would use ally sheet and rivet and glue it together, the steel book design is very heavy.
Paul.
Hi all
any ideas welcome
regards phil.....
New Topic New Reply
