| posted on 1/1/08 at 02:21 PM |
Pedal feel
Take a look at this -- a lot of builders don't realise how much pedal feel and stopping power is robbed by it.
It dosen't just affect the MGF -- a lot of mainstream cars and kit cars suffer from it.
I had a Lotus Plus2S that had lousy brakes until I braced the master cylinder.
Test your build by getting a mate to pump the pedal hard on-off--on-off-onoff-on-off while you feel he master cyilnder for movement.
More details details here http://www.mgf.ultimatemg.com/group2/common_problems/brake_servo.htm
[Edited on 1/1/08 by britishtrident]
| posted on 1/1/08 at 02:28 PM |
more
| posted on 1/1/08 at 02:34 PM |
People have failed SVA for less movement than that!
nitram38
| posted on 1/1/08 at 02:55 PM |
What you are showing is bulkhead flex.
Most 7's have small footwells and are welded alround, so hopefully this is quite rare on here!
| posted on 1/1/08 at 03:17 PM |
Actually I suspect it's not uncommon having seen plenty of master cylinders mounted in the footwell with little bracing.
