Author: Subject: whats't he best way to press bearings in?
blakep82
posted on 10/1/08 at 12:22 AM Reply With Quote
i've got these type of bearings
http://www.fag.com/content.fag.de/en/ina_fag_products/productinformation/rotativ_products/cylindrical_roller_bearings/high_precision_cylro/hochgenauig keits-zylro.jsp
meant to take some pics of the hubs while i was out there, but i forgot my phone.
whats the best way to put them in.
crap drawing
bearing
bearing
i thought they'd be easy enough, but was worried about damaging them. pressed one most of the way in using a vice and some peices of wood to stop the jaws damaging it, but i can't get the seated as far in as they should be.
what to do?
________________________
oadamo
posted on 10/1/08 at 01:08 AM Reply With Quote
big socket and tap them in with a hammer.
adam
Mr Whippy
posted on 10/1/08 at 01:17 AM Reply With Quote
can you not find a socket to go on top?
I'd be weary of using a hammer on them but if you do make sure you use a drift, brass is best and spread the impact over as large an area as pos, wheel bearings are easy damaged.
nitram38
posted on 10/1/08 at 05:45 AM Reply With Quote
You can use a vice with the correct sized socket, but favourite is have a chat with someone with a bearing press.
It will not only make the job quick, but also ensures the bearing goes in straight.
RickRick
posted on 10/1/08 at 07:43 AM Reply With Quote
heat up the hub, that should help the bearing slide in.
flak monkey
posted on 10/1/08 at 07:52 AM Reply With Quote
You are fine tapping a bearing into a housing, as long as you hit on the outer race and not the inner, otherwise you will damage the track and balls/rollers. The best way to help them in is to use a smear of bearing assembly paste, or thick grease. Not much though.
If you do hit it too hard you'll break the race, but it should never be that tight!
Sera
http://www.motosera.com
fatfranky
posted on 10/1/08 at 08:19 AM Reply With Quote
My personal favourite has always been to take the old knackered bearing and grind a small amount off the outside of it so that it is slightly undersize and then use this to drive/press the new bearing in.
This ensures that you are pressing on the outer race and therefore not damaging the bearing and is also a nice square fit.
This assumes of course that you are replacing the bearing and not refitting the old one.
NigeEss
posted on 10/1/08 at 08:36 AM Reply With Quote
Much easier to slice it (old race) into a C shape with the wizzer than grinding all
round the outside.
Or as Flak says, tap it in. Go gently from one side to the other moving round as
required to keep it perpendicular.
[Edited on 10/1/08 by NigeEss]
blueshift
posted on 10/1/08 at 09:15 AM Reply With Quote
"wizzer", I like that
my angry grinder has a new name.
nige
posted on 10/1/08 at 09:35 AM Reply With Quote
bearings
please
"DON,T USE A BRASS DRIFT"
brass splinters
copper is much better
or as above , old race or socket
pressed in a vice
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
Johnmor
Bearing press
The best way is to use a socket slightly smaller than the outer race and a bearing press/ or a large vice
I made a press using some 40mm box section and an 8 ton hyrdaulic jack, just have the jack sitting the right way up instead of mounted in the top rail.
Only cost me around £30 for the stuff and its been one of the best 30 I've spent.
The danger of hammering is you send a shock throught the bearing and dislodge the ball bearings out of the plastic retainer in the inner race and end up with a heap of bits rolling around the floor.
I have a 3/4 socket set and i've used it more for pressing bearings than undoing sockets
http://www.machinemart.co.uk/images/library/product/medium/02/020410030.jpg?
bassett
posted on 10/1/08 at 04:40 PM Reply With Quote
Could try putting the hub in the oven and the bearing in the freezer.
Adam
blakep82
posted on 10/1/08 at 06:27 PM Reply With Quote
the bearing's 4" diameter (approx) and i don't have a socket that big
hub is alloy so i probably want to avoid heating it... bearing in the freezer though! I'll do that
one of them#s already half way in, so need a bit more work, but i'm gonna put the bearing in the freezer now so it'll work later
