Author: Subject: Uaing upper wisbones to lever inboard springs
Jesus-Ninja
posted on 17/1/08 at 11:46 AM Reply With Quote
Is this an option? As far as I understand, things are best used in compression or tension.
By using extending one of the arms on an upper wishbone inboard, such that it acts downward on a spring / shock, is it asking a single component to do too much?
Or is it just that it needs engineering in a different way to handle the bending loads?
Has anybody any first hand experience of such a system?
nib1980
posted on 17/1/08 at 11:48 AM Reply With Quote
It is doable, I believe that the formula 27 is like this (someone correct me)
But I think personnaly it requires some carful engineering, and If it was a better of doing it why has't F1 adopted it? they still use push rods i believe?
tegwin
posted on 17/1/08 at 11:51 AM Reply With Quote
Doing this is a very very common thing on quite a few cars...
F1 cars of the past have used this system but changed in favour of pushrods to allow rising rate, antidive/antisquat to be controled.
The car that springs to mind, is Kurt's mid engined mini...that has upper A arm lever type shock mounts...
hughpinder
posted on 17/1/08 at 11:59 AM Reply With Quote
See the onyx mongoose, sylva riot ....
posted on 17/1/08 at 12:05 PM Reply With Quote
yep - top wishbone is single box with pivot bush about half way - other end acts to compress spring/shock.
photo shows plan built i.e ancient but I believe it is similar in principle on current model.
escort mk2 rack?
escort mk2 rack?
StevieB
posted on 17/1/08 at 12:15 PM Reply With Quote
Sriker does the same thing too, but the upper wishbones are much more meaty than standard items and, as said, the geometry needs to be well thought through
Jesus-Ninja
posted on 17/1/08 at 12:27 PM Reply With Quote
How is location of the top of the upright controled, given that the upper wishbone is a single arm? Is control of caster under breaking, for example, an issue, as the upright tries to "revolve" around the same axis as the wheel.
Is it simply very strong and well located inboard - I'm guessing it pivots on a long(ish) shaft rather than a short shaft. Certainly a spherical bearing wouldn't work!
nitram38
posted on 17/1/08 at 12:31 PM Reply With Quote
If you go this route, you will have only the spring seats to adjust ride height.
If you use a rocker or cam with a pushrod set up, you will still be able to adjust ride height but without changing the spring rate.
To make the rocker/bone setup work, you make have to experiment with different springs to get it right.
Jesus-Ninja
posted on 17/1/08 at 12:39 PM Reply With Quote
I have coilovers which provide adjustment of the length of the unit independently to preload/spring platform.
nitram38
posted on 17/1/08 at 12:48 PM Reply With Quote
Then I can't see any problems.
If you design the set up as normal unequal "A" wishbones for your desired camber change, then use the top bone mounts as your pivot point, all you have to do is extend an arm to your shocks.
Remember that a 1:1 ratio will require the arm to be the same length of the wishbone. So ensure you have enough space.
You could change the length of the arm, but you would have to change your shock/spring rating too.
Remember also to build in some sort of strengthening to stop the bones bending.
[Edited on 17/1/2008 by nitram38]
Rocker wishbones put much larger loads into the chassis. Although this can be engineered round a lot of manufactures and home builders don't understand the implications and as result both the wishbone and the chassis deflect elastically a lot more and in effect act as an undamped spring. The damper will also run hotter.
However it has two advantages the coilspring damper unit can sit at a more upright angle and move in a 1:1 ratio with the wheel.
The other advantage only applies to open wheel cars --- less drag.
Used by Lotus on the 24/25/33 and some 70s F1 cars.
lsdweb
posted on 17/1/08 at 01:08 PM Reply With Quote
Here it is on my single seater - link (Pre BEC conversion btw)
Note the rockers are not equal either side of the pivot - it's a2:1 ratio (roughly)
There's an aerodynamic advantage but also a weight penalty!
Wyn
posted on 17/1/08 at 01:25 PM Reply With Quote
As you can see from photo, the chassis is doulbed up - reading what BT says - is there for strengtrh - I wondered why.
there are two brackets underneath, bolted to chassis with a tube/bush arrangement.
If you are dead interested, I can take photo; there may be one in my archive.
Jesus-Ninja
posted on 17/1/08 at 01:39 PM Reply With Quote
Well, I wouldn't go out and start snapping just yet...
Amongst a list of options, one I am considering is a rocker arm, but use a tension arm running backward to the chassis to control hoizontal movement of the top of the upright.The rocker would still have to be beefy enough to resist bending in the vertical plane, but there should be much less loading horizontally.
lsdweb
posted on 17/1/08 at 01:48 PM Reply With Quote
I forgot to say the single seater arrangement has two rockers with adjustable push/pull rods for adjustment, independent of the spring platforms.
Wyn
posted on 17/1/08 at 02:43 PM Reply With Quote
Note that using the transit drag link end in conjunction with the rocking wishbone arrangement is not a good idea at all. The Sylva Striker uses either a Metro or (i think) a Vauxhall Viva ball joint depending on age.
Jesus-Ninja
posted on 17/1/08 at 03:03 PM Reply With Quote
I'll would be using a rose joint between the upper rocker arm and the upright. The rose joint will mounted vertically on the upright, with the rocker arm bolting through it, such that the joint end doesn't experience any bending.
posted on 17/1/08 at 04:57 PM Reply With Quote
Metro ball joint has a lot going for it in this situation.
Syd Bridge
posted on 17/1/08 at 06:01 PM Reply With Quote
Are you trynig to make the front end as heavy as possible?
This would be a good start to that end.
Syd.
Dingz
posted on 17/1/08 at 07:41 PM Reply With Quote
Here is a shot of the (early) Robin Hood inboard setup. Rescued attachment top susp.jpg
