sammy
| posted on 21/1/08 at 09:49 PM |
M14 thread connectors
For extending the track rods on a mk2 escort rack.
Loads of places do M14 threaded bar in high tensile steel, and a lot places do thread connectors (short length of hex bar drilled and tapped).
However, the connectors never seem to be available in M14, they always seem to jump from M12 to M16.
(For example: http://www.fastfixdirect.co.uk/code/navigation.asp?fType=Fasteners&MainCategoryID=4&ProductCategoryID=126 )
Does anyone know anywhere that does M14 connectors or will I have to get some hex bar and make my own (or rather get my mate to do it!)
Build diaries...
snapper
| posted on 21/1/08 at 09:59 PM |
Rally Design
I eat to survive
I drink to forget
Confused but excited.
| posted on 21/1/08 at 10:09 PM |
Or try FWB. I have had 10mm from them.
| posted on 21/1/08 at 10:36 PM |
quote: Originally posted by snapper
Rally Design
If they are the GTS ones then they are made from an aluminium alloy. I bought some and ended up turning them down to make some spacers for something
as I just didn't fancy having alloy sections in my steel track rods (bought before I had a lathe).
[Edited on 21/1/08 by MikeRJ]
blakep82
| posted on 22/1/08 at 12:44 AM |
seen enough racing cars with theaded alloy tube for 4 link axles, BECs too, never seen to fail.
i got a pair of the rally design ones, i like them
________________________
mistergrumpy
| posted on 22/1/08 at 01:16 AM |
Yeah I tried everywhere for m14 threaded connectors but they just don't seem to exist. Dunno how people join the threaded rod. Had to buy
extenders from GTS in the end. Rally Designs are from GTS just without the same wait
907
| posted on 22/1/08 at 03:34 AM |
Mmmm, I wasn't able to buy the size I needed so I made mine from studding and m/s round bar.
Locked the thread in place with a roll pin. (see pic)
Paul G
t.j.
| posted on 22/1/08 at 07:28 AM |
Paul G
Why not the thread on the round bar?
Is that due strenght problems or just easier to fabricate?
Ian D
| posted on 22/1/08 at 07:52 AM |
Try Kebrell nuts and Bolts.
| posted on 22/1/08 at 08:46 AM |
Did those tubes have male threads formed at the ends? I suspect they had steel rod ends screwed into inserts in each end of the tube...
| posted on 22/1/08 at 09:45 AM |
I've not come across M14 threaded bar. The thread used is ISO standard not some rare fine thread so it should be possible to track down.
I had to have some extensions made from one 25 mm HT bolt. Cut, dDrilled and tapped and turned down so I could put on a thread - the hardest part.
there are hand filed hex flats to a spanner could be used.
  extensions
907
| posted on 22/1/08 at 05:24 PM |
Paul G
Is that due strength problems or just easier to fabricate?
Sadly my turning ability does not extend to machining threads, and I couldn't justify buying a die just to cut two threads.
It was bad enough spending £14 on a tap.
atb
Paul G
Wingnut
| posted on 23/1/08 at 12:13 AM |
I bought these from Westfield just the other day, 9 quid odd each plus VAT - M14 X 1.5
Hope this helps!
