Author: Subject: Cant get my shaft in!
nathanharris1987
posted on 12/2/08 at 04:31 PM Reply With Quote
sierra alf sharfts right...
I cant get the splined bit fully in, when i ripped it out the donor i seem to remember it being bout half inch - inch furthr in. Any body else get this problem or should one just lube up and apply man force?
ta
Mr Whippy
posted on 12/2/08 at 04:48 PM Reply With Quote
is the ring clip jammed, don't force it. Take it out and double check. Really you are meant to change the clip as they deform once released.
looks about as far in as I remember it went. Have a look at someones archive pics.
[Edited on 12/2/08 by Mr Whippy]
andyace
posted on 12/2/08 at 05:07 PM Reply With Quote
It will go in till it meets the oil seal.
Mine went in quite easily but it does need a little jiggling. No excessive force should be required though.
nathanharris1987
posted on 12/2/08 at 06:33 PM Reply With Quote
ring clip? which bad boy is that ?
posted on 13/2/08 at 09:47 AM Reply With Quote
Looks about right to me - have you got a piccy from directly above?
Can you get the rear upright/hub/brake assembly together OK? If so then it's far enough in.
