New Topic New Reply
Author: Subject: Indy damper bolts
JEPY
posted on 13/2/08 at 08:03 PM Reply With Quote
Indy damper bolts
Hi all,
Just building up the suspension at the moment and the supplied bolts for the mounting the coilover dampers are M12. However, the Indy build article in Which Kit Car reckons that they should be 1/2".
Who's fitted what? I've used the M12's so far, but it's now niggling at me...!
mackei23b
posted on 13/2/08 at 08:57 PM Reply With Quote
M12 bolts on mine.
Ian
P.S. My Dampers were sleaved to 12mm
[Edited on 14/2/08 by mackei23b]
jacko
posted on 13/2/08 at 09:29 PM Reply With Quote
m12 on mine
skodaman
posted on 13/2/08 at 10:11 PM Reply With Quote
Sorry to hijack the thread but I have some MK trailing arms. Fitted them to the chassis with 12mm bolts and yup there's just a bit of freeplay. So I guess they're supposed to be half inch as well. Think I'll just make some new one's as they're longer than the book ones anyway.
Skodaman
posted on 13/2/08 at 11:23 PM Reply With Quote
M12 as supplied by MK with the kit (4 years ago mind)
Bluemoon
posted on 14/2/08 at 09:15 AM Reply With Quote
If they are done up tight (car on the ground) I doubt it matters, the tube in the damper should be compressed, and it's the compression that holds it in place.. The bolt should not be use as a point of rotation for the bush, only the rubber should twist...
Mine are M12, 8.8.
Dan
JEPY
posted on 14/2/08 at 09:52 PM Reply With Quote
Thanks everyone - I'll pick up a set of 1/2" bolts tomorrow. At this early stage, I might as well not risk it later.
Robocog, I'll be avoiding your MOT man!!
iank
posted on 14/2/08 at 10:21 PM Reply With Quote
At the risk of igniting another round of flaming
http://www.locostbuilders.co.uk/viewthread.php?tid=72746
Anonymous
Stuart_B
posted on 15/2/08 at 07:32 PM Reply With Quote
hi, after reading this thread i am now concered about what to do, i got my kit 3 months a go, so will i need to change the damped bolts, as i got m12 bolts in my kit?
Sorry do not mean to hijack the thread.
thanks
stuart
tomblyth
posted on 16/2/08 at 07:42 AM Reply With Quote
Its not the MK kit its the dampers Gaz dampers have a 1/2 inch bore so use 1/2 inch bolts with shoulder, other dampers may use 12mm not sure as i only have gaz shocks. measure and use what is the best fit. remember also only use grease which has no mineral base (eg silicon push bike grease on the plastic bushes)
mackei23b
posted on 16/2/08 at 12:01 PM Reply With Quote
You can get inserts from Dampertech to reduce from 1/2 inch to 12mm
Ian
[Edited on 16/2/08 by mackei23b]
New Topic New Reply
