JEPY
posted on 26/2/08 at 09:37 PM |
Has my column collapsed?
I hadn't paid much attention to the column since stripping the donor car last year. However, this evening I started cleaning up the column and
saw that it was quite different to the one in the Haynes manual (haynes show's like a concertina).
in short.... has it collapsed???
Advice appreciated...
![](/galpreviews/a699759-P1010007_small.JPG) ![Rescued attachment P1010007_small.JPG](/gallery/a699759-P1010007_small.JPG) Rescued attachment P1010007_small.JPG
snapper
posted on 26/2/08 at 09:38 PM |
No its an adjustable column,
I thought the same but yours looks exactly like mine.
I eat to survive
I drink to forget
JohnN
posted on 26/2/08 at 09:42 PM |
Another
NO!!!!!!!
Looks the same as mine apart from the welded washer in front of the spring is up inside the concertina bit.
tks
posted on 26/2/08 at 09:48 PM |
the collapsable part is the spring part.
Also its the part where the triangle tube is the inner tube of the outer tube, in a accident that tube will slide further into the other tube.
Tks
JEPY
posted on 26/2/08 at 09:59 PM |
Thanks guys, was about to throw a paddy this evening when I thought it might be scrap!
Will save cleaning it up until tomorrow night now...
triumphdave
posted on 26/2/08 at 10:07 PM |
Do you feel like you are constipated?.........
sorry just read again "COLUMN"
