Author: Subject: What is this?
scoobyis2cool
posted on 1/11/03 at 02:55 PM Reply With Quote
What is this?
Can anyone tell me what this is? It's at one end of the front to rear brake pipe that came as part of my Indy kit. Rescued attachment BrakeConnector.jpg
ChrisW
posted on 1/11/03 at 03:14 PM Reply With Quote
Brake light switch screwed into a 3 way brake union? Or am I missing the point?
Chris
My gaff my rules
scoobyis2cool
posted on 1/11/03 at 03:19 PM Reply With Quote
no you didn't miss the point, I thought that's what it was but wasn't sure. Is this supposed to go at the front or back of the car?
posted on 1/11/03 at 03:28 PM Reply With Quote
I would put it in the line to the rear brake circuit as the pressure to rear is lower and the wiring is nearer. Just my opinion.
yours, Pete.
bob
posted on 1/11/03 at 06:05 PM Reply With Quote
posted on 1/11/03 at 10:46 PM Reply With Quote
Pressure activated brake light switch, our is located about 150mm from master cylinder heading towards the prop tunnel. No long pipes or wires depending on where fuse/distribution box is...
greggors84
posted on 2/11/03 at 02:17 AM Reply With Quote
On the MK brake line kit, it was screwed into the piece of brake line labelled as the rear, so thats where we are going to put it, just past the MC, which will be nearest most of the wiring.
Just look and i havent got any pics of the rear brake lines.
Chris
The Magnificent 7!
givemethebighammer
posted on 2/11/03 at 04:25 PM Reply With Quote
I was told by the guy that services my volkswagen that it should not matter where you put the switch in the braking system, because it doesn't affect the performance of the line it is in anyway.
Don't know if this is correct but mine is in one of the front brake lines. It was IMHO easier to access there than at the rear of the car.
scoobyis2cool
posted on 2/11/03 at 04:44 PM Reply With Quote
Where can I get a brake bias valve from and how much do they cost? Would I be better off getting a second hand one? If so, what car do i look for to get it from?
Mk-Ninja
posted on 2/11/03 at 05:11 PM Reply With Quote
Brake Bias Valve
You can get a wilwood one for about £70 or you can use one off a Fiat Uno, about £5 from the scrappers.
Gordon
I'm sure I've got one, just don't know where I've put it
greggors84
posted on 2/11/03 at 07:15 PM Reply With Quote
I picked up a wilwood one for £20, ill email the bloke and see if he has got one left, as he had two. I will U2U you when i know.
Chris
The Magnificent 7!
scoobyis2cool
posted on 2/11/03 at 10:40 PM Reply With Quote
Yeah that'd be great Chris, cheers
Pete
