matt_claydon
posted on 6/11/03 at 06:32 PM |
Urgent Q Re Fiat bias valve
I need to know which way the Uno bias valve works - does is let more power to the back brakes when you stop the plunger or when you let it come all
the way out?
Want to set the balance on the way to SVA tomorrow and suddenly realised I don't actually know which way to adjust!
bob
posted on 6/11/03 at 07:28 PM |
Matt
The plunger rises when you put pressure on,so i am presuming if you hold it down this will reduce the flow to rear.
The best way to find out for sure is mail or u2u theconrodkid (john)
good luck tomorow
Ben_Copeland
posted on 6/11/03 at 07:31 PM |
Undo it all the way, slam the brakes on hard... see what happens
P.S. think i heard somewhere the adjuster has to be fixed for the SVA
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
theconrodkid
posted on 7/11/03 at 12:42 AM |
you screw it in to increase pressure to the backs,good luck with your test
who cares who wins
pass the pork pies
James
posted on 7/11/03 at 11:21 AM |
Good Luck mate!
Tell us how it went.
James
