charlierevell
| posted on 19/3/08 at 06:09 PM |
Is this 7 or 7.5inch????
Hi Guys,
What diff do you think this is...
DIFF
Would it fit a Dax rush previously with a 2l EFI pinto and now with a cossie lump???
Tango orange is an 'IN' colour!!
twybrow
| posted on 19/3/08 at 06:11 PM |
7.5" for the cosworths. I think you would want a diff from an XR4i (or is it XR4x4?!)...
Syd Bridge
| posted on 19/3/08 at 06:19 PM |
I've said this every time this subject comes up...
Sierra 4x4's came with 7" and 7 1/2" diffs.
I've had three come through my hands in the last ten years, and all had 7.5" diffs. I've still got one set of running gear complete,
and it is definitely a 7.5" diff.
Ford in their wisdom, put in what they had to hand on the day, as it appears.
And Cosworths came with 7.5" diffs, except for the RS500 and better, which had 9", same as GpA.
Syd.
I've got a 7.5" Cosworth diff in the shed, if anyone is wanting one.
[Edited on 19/3/08 by Syd Bridge]
charlierevell
| posted on 19/3/08 at 06:30 PM |
Just interested as a mate has bought it for his Rush and I'm not sure it will fit!
locoR1
| posted on 19/3/08 at 07:21 PM |
That looks like a 7” to me on the 7.5” diff the top mounting is solid the 7” its hollow in the centre of the mounting, when fitted you can see the
bolt running through the centre of the mounting!
Check out my CB500T Cafe Racer build diary
SALAD
| posted on 19/3/08 at 07:25 PM |
Ditto what he said ^^^^^
eznfrank
| posted on 19/3/08 at 07:27 PM |
I have a 7" LSD 3.62 off an XR4x4 and I would say is the same as mine.
IDONTBELEIVEIT
| posted on 19/3/08 at 07:33 PM |
7" deffo
Are We There Yet, Are We There Yet!!!!
TOO BADD
| posted on 19/3/08 at 08:00 PM |
Believe you measure the width of the casing at each end where the long bolt goes in at the top which should be either 7 or 71/2 inches
chris_harris_
| posted on 19/3/08 at 08:49 PM |
Looks very much like a 7" to me. And mine which came out of a cosworth 4wd) is a 7" lsd, so who knows what they where thinking when they
bolted them all up!
Regards Chris
| posted on 19/3/08 at 08:59 PM |
That's a bit of a fluke if it does as the size refers to the crown wheel.
mcerd1
| posted on 19/3/08 at 09:35 PM |
as above its definatly a 7"
Syd.
you must have got some weird 4x4's then all the ones I've ever seen (inc cossie 4x4) have been definatly 7"
I thought the main problem with 7.5" on the rear of a 4x4 was that they didn't make any front ratios [6.5"diff] to match
but then over the years ford have done all kinds of weird things to use up the spare parts....
Liam
| posted on 20/3/08 at 12:03 AM |
Of course I wouldn't dispute that Syd could well have picked up 3 4x4s with 7.5" rear diffs, but they'd be the only three out
there... in the entire world! Everyone else in the history of humanity has found a 7" diff on the back of their 4x4s, whether XR or cossie .
You're right mcerd1 that a 7.5" would be 3.64:1 rather than the 3.62:1 to match the front diff. That said, the resulting approx 0.6%
speed difference between the front and rear axles helping to keep the centre diff VC toasty probably wouldn't have stopped Ford shoving a few
wrong diffs on if they felt like it on a friday afternoon (though it was only a 0.9% speed difference 'design fault' that killed early
Freelander centre VCs, normally locking them solid giving rise to horrible tyre wear, and after that transmission failure).
Oh as above that's a 7" - easily identifiable by the hollowed out top mount. So that seller is evil and lied about it coming off a 2WD
cossie.
Liam
mcerd1
| posted on 20/3/08 at 10:21 AM |
or a 3.91 [7.5"] instead of a 3.92 [7"]
(the only 4x4's to get 3.92 ratio's were 2.0 XR4x4's)
- from that ebay description I wouldn't trust anything
its defiantly a 7" with 100mm bolt-on shafts, but the rest is anyone's guess
so I'd want to check the ratio and the LSD claim myself before bidding
anyway, to answer the last part of the original question:
If the Dax in question has a sierra diff at the moment then any 7" or 7.5" diff should fit (assuming its a DeDion - if its an IRS I think
thats still true, but I'd have to check)
its just a case of making sure you have the right hubs and shafts to match, but I assume that he'd rather keep the shafts and hubs he's
got if he can
chances are that a 2.0 pinto car will have the 2.0 pinto diff, so it will most likely be a 7" with push-in shafts and drum brakes if it all came
from a sierra, but it could be bolt-on, or 7.5" - so best to check if your/ he's not sure
btw - tell your mate to get himself over here: http://forum.rushowners.co.uk/phpBB2/ and say hello (if he hasn't already)
-RD
[Edited on 20/3/08 by mcerd1]
charlierevell
| posted on 20/3/08 at 11:16 AM |
Well ATM its got Discs on the back not drums. Havent looked into it any further than that but ill pop over and have a look at it over easter if its
arrived.
Syd Bridge
| posted on 20/3/08 at 11:32 AM |
The cars I had were all Island cars, if that makes a difference.
First two were 2.8's, the last a 2.9.
I've still got the last running gear in a car in my back yard, if anyone wants to have a look. And definitely 7.5".
Syd.
