Johneturbo
| posted on 23/3/08 at 06:38 PM |
Braided line to wilwoods
Hey guys
I tried to fit my Goodridge braided lines to my wilwoods,
but they are both males ends
is there an easy solution. maybe an inline female?
Johneturbo
| posted on 23/3/08 at 06:46 PM |
Paradoxia0
| posted on 23/3/08 at 06:52 PM |
I got some female to female adapters when I was first putting the car together as the original builder had the wrong ends on the copper lines. Cost
about £4 from a motor factors.
Mark
Johneturbo
| posted on 23/3/08 at 07:19 PM |
Thanks for the reply.
that sounds like an easy option.
just had a look at rallydesign, only thing i can find is this
HERE, but it means cutting the braided line
worX
| posted on 23/3/08 at 07:29 PM |
If you were going to cut the ends off I think that you would be better off mating it to the male/male that's already in there with something
like THIS that way you can still attach it by just
tightening up the "nut" instead of spinning the whole brake line around...
BUT - Thant may not be the exact one for you, I was just using the link to show you the example of the Female part instead of your idea of the male
part.
The second reason I'd do it my way is because if you did it your way, you'd lose quite a bit in length and according to my Mrs.
that's not a good thing...
indykid
| posted on 23/3/08 at 07:32 PM |
that's what i bought for mine. (the male 1/8th npt fittings)
i really don't think running 2 adaptors to get hose to mate to caliper is wise at all. can anyone say fatigue failure?
since the unions will be put in bending every time the wheel is turned, making the moment arm as short as possible would seem to be good practice.
either buy the hose ends, or buy new hoses. don't just go whacking adaptor on adaptor.
tom
[Edited on 23/3/08 by indykid]
Johneturbo
| posted on 23/3/08 at 07:42 PM |
Yep i know what your saying steve, but i do have a lot of lenth anyway...
i did read somewhere that Mr sva only likes crimped ends on braided lines?
worse case is i buy two new lines and sale these on, as they are brand new.
indykid
| posted on 23/3/08 at 07:47 PM |
as long as you can provide the sva inspector with a photo to show the inner hose is supported, as it is with those fittings, you can use compression
fittings.
i know of at least one car that passed without question with those type of fittings.
tom
nitram38
| posted on 23/3/08 at 08:01 PM |
Doesn't the union in the wilwood unscrew and the braided line screw in directly, or have I missed something?
russbost
| posted on 23/3/08 at 08:07 PM |
"Doesn't the union in the wilwood unscrew and the braided line screw in directly, or have I missed something?"
- No, in their wisdom Wilwood use 1/8 27 NPT threads in their calipers.
I obviously have a vested interest here as I would happily sell you new braided lines made to your exact specs for £15 each if less than 0.5m - but I
certainly wouldn't use an adapter to join the 2 male ends as you are going to finish up with a heavy unwieldy lump flexing the caliper adapter
end. Just my humble opinion.
skippad
| posted on 24/3/08 at 09:19 AM |
ive just been fitting front wilwoods yesterday and the male end of braided hose screwed into caliper ok and did'nt leak.
Thought all was ok until i tried full lock and found hose little short...bugger!
So i'll need to change longer hoses!
Do u think i've damaged the caliper seat where male fits into caliper?
Jon Ison
| posted on 24/3/08 at 09:29 AM |
Don't think so, that's what I did.
skippad
| posted on 24/3/08 at 09:41 AM |
Does that mean it did'nt fit properly?
skippad
| posted on 24/3/08 at 10:05 AM |
Ah!! i see now...it did fit! (sorry me hangover's just clearing)
cloudy
| posted on 24/3/08 at 11:38 AM |
Worth buying the right ones, I have some of russ' brake lines - top notch
James
gazza285
| posted on 24/3/08 at 12:13 PM |
No you didn't, not if you mean the Wilwoods I bought off you, those had a female end on the flexy.
Johneturbo
| posted on 24/3/08 at 03:01 PM |
I did try that but found it went a few turns (by hand) then went tight the wilwood adapter screws in all the way by hand.
what braided lines have you got skippad?
Jon Ison
| posted on 24/3/08 at 03:18 PM |
Here's a pic of mine, scuse the rust.
The Great Fandango
| posted on 24/3/08 at 11:13 PM |
Oh poo!
Seems I have found myself in a similar situation to others on here?
My lovely new group-buy Wilwood Powerlite calipes are now mounted correctly to the front of the car.
Problem 1:
The braided flexi lines are now too short to allow full lock
Problem 2:
The Wilwoods come with a brass connector making the situation male to male.
I presume you don't actually have to use the supplied connectors if you can find a braided line that fits straight in?
Can someone suggest where to get hold of (or point out an exact set) of suitable flexi lines?
I'm a complete beginner when it comes to brakes lines and flexi lines. Heck, I had just spent 3 months working out which calipers to purchase...
The whole thing can sometimes really get me down.
[Edited on 24/3/08 by The Great Fandango]
He Who Dies With The Most Toys Dies The Happiest
skippad
| posted on 24/3/08 at 11:52 PM |
The braided lines are Mk standard issue.
Its all sorted now...found 1m of braided hose in back of garage cupboard which i bought a few cars ago.
Also found enough male convex seat fittings, fitted ok into Willwood calipers NO
leaks.
All done, nice firm pedal...just needs a drive out to bed in, when it STOPS SNOWING.
russbost
| posted on 25/3/08 at 05:35 PM |
The Wilwood calipers have a 1/8 x 27 NPT Tapered female thread, so far as I am aware they don't make them with anything else. Also so far as I
am aware the only way you can get a brake line with the CORRECT Npt thread is by using the self assembly type lines which it looks as tho' Jon
has from the pic he's posted - we can all see what they look like after being fitted for a few years! I don't believe anyone makes a
"proper" flexy braided line with a Npt end - I certainly don't. I would supply the adapters such as I posted here
Link
I think these with a nice shiny STAINLESS steel union attached will definitely look more attractive than rust!
As regards anyone haveing damaged a "seat" there is no seat as such because Npt threads seal on the taper - hence why you shouldn't
be screwing anything else in there! HTH
