| posted on 8/11/03 at 05:34 PM |
SIERRA BRAKE PROBLEM
Despite exhaustive research on fitting correct disc's, we have dropped a bo**ock somehow.
OKAY so... we're now at this stage!
New Disc's purchased - 4x4 (260mm diameter)
New Calipers from MK (told to suit 4x4)
New Standard Uprights from MK
Problem is now... Calipers will not 'flush up' to upright due to disc outside face. This leads me to the question - are the Calipers REALLY
from 4x4? If not I need to return the disc's as I guess the Calipers are from XR4i NOT 4x4 as the offset is different!
Ideally I would like one of you guys to measure the front disc face to front front pad face and inform of measurement. I currently measure at 29.15mm
but needs to be around 34~35 for correct alignment.
PLEASE HELP!!!
AvonBelgium
| posted on 8/11/03 at 07:31 PM |
Take a look at www.brembo.it.
Go to "aftermarket" then "cars" en there you can open a compleet cataloge with dimensions from discs
[Edited on 8/11/03 by AvonBelgium]
| posted on 8/11/03 at 11:28 PM |
THANKS....
A very big thank you to AvonBelgium, that is the most worth while link ever. It sorted out the problem, answered our questions. Now how much do I pay
for the surcharge???
Bloody 'Hellfire'
