Mr Whippy
posted on 6/4/08 at 11:37 AM |
Why I hate Vauxhall Vectras
This will be why the ABS light was on
This car hasn’t even got past 90k and look at the rust! Can’t even get those nuts off to replace the disk as they’ve rounded inside, I’ll have to use
the grinder now What a total rip off these cars are
Liam
| posted on 6/4/08 at 11:39 AM |
Blimey how old is that?!
Do you drive to work accros damp salt flats?
Liam
bigrich
| posted on 6/4/08 at 11:49 AM |
did'nt know the titanic had ABS
looks like its from the bottom of the sea
Mr Whippy
| posted on 6/4/08 at 11:51 AM |
9 year old, worth as much as a melted mars bar
this is the forth VH I've had and they've all been b*ll*cks, never again
I've only went and bought a heap of parts for it and now seeing just how horrible it is wish I hadn't, feck!!! wonder if they'll
take them back???
Should have smashed it up with the digger after all....what a sh*tty Sunday this is, very sad, I need a drink
twybrow
| posted on 6/4/08 at 11:53 AM |
You can buy mine from me!? 1.8 petrol estate load lugger on an R-plate with 136k (and no rusty brakes!)...
| posted on 6/4/08 at 12:09 PM |
ive got a veccy outside that i parked up fine 5 months ago and now is dead as a doornail! Shite engines too.
Mr Whippy
| posted on 6/4/08 at 12:19 PM |
well I stuck it in 4th and jammed a screwdriver against it, most of the rust has come off. Not much left of the ABS teeth I suspect it needs a new
drive shaft or two haven't even looked at the back brakes... scrap car, what a waste of money that was.
blakep82
| posted on 6/4/08 at 12:23 PM |
thats aberdeen for ya
________________________
fesycresy
Told the wife I need to change her cambelt.
Wife decided to sell her Vectra, so said don't bother.
A few days later, said cambelt lets go
Just the parts cost me over £300
I hate Vectras too.
mookaloid
| posted on 6/4/08 at 12:36 PM |
I hate Vectras - I only had one for six months - 3 yr old and it cost me about £1500 in repairs in that time. had to take a big hit when I traded it
in too. Utter crap I'll never have another
The honda accord I replaced it with never missed a beat for the 18 months I had it but used a bit more petrol than the Vectra
blakep82
| posted on 6/4/08 at 12:39 PM |
easy way to fix the abs light:
remove the bulb.
it'll never annoy you again after that
considering we all build cars on here without worrying about ABS, i don't think you'll miss it much
Mr Whippy
| posted on 6/4/08 at 12:44 PM |
Is it not part of the MOT test though? if the inspector see's that he won't even need a light to tell him it knackered...
Liam
| posted on 6/4/08 at 12:52 PM |
Crikey - LOL at those ABS teeth! Probably cast from left over furnace slag. If it makes you feel any better - I've got a decent vauxhall (the
only one?) - my pimpin omega elite . Nearly 10 years old now and just gone over 100k. Been a joy to own for the last two and a bit years. No
rust. Only cost me a grand in the first place. The Griffin is strong in Bedford
Liam
blakep82
| posted on 6/4/08 at 12:53 PM |
i don't think so... my last 2 cars, E30 bmw, had the bad pad warning light on because the plug was broken for the sensor to the brake pads. told
them about it and they said thats not part of the mot. as long as they work. the E36 bmw the airbag lights are on, been through at least 2 mots with
that.
i think abs is one of these non essential driver aids (i think!) so if it doesn't work, i don't think its a problem. maybe want to have a
word with a garage you're NOT taking it to for mot
Mr Whippy
| posted on 6/4/08 at 01:00 PM |
that.
hmm ok cheers I'll pop into the local garage and see what they say. I've had so much grief from this car
| posted on 6/4/08 at 01:09 PM |
If ABS is fitted then the warning light must illuminate and go out after a few seconds when the ignition is switched on. If it doesn't come on
at all or stays on it is an MOT fail.
eccsmk
| posted on 6/4/08 at 01:48 PM |
that.
if the e36 is the same as the e46 the plugs under the front two seats cause airbag light faults
also on the e30 you can remove the pad warming light by disconnecting the wiring at the diagnostic plug
| posted on 6/4/08 at 02:29 PM |
Neither airbag or pad warning lights come into the MOT . Pads worn below 1.5mm are a fail though. ABS on the other hand should have the warning light
come on when the ignition is switched on and follow the correct sequence for the vehicle being tested. Some cars like the Freelander have to be driven
above a certain speed for the light to go out, others go out after a few seconds. P.S. I hate Vectras as well
Mr Whippy
| posted on 6/4/08 at 02:37 PM |
So much for that then
I'm not having a good day...went off to check her car to find out which wheel bearings making a racket, till I find she's off with the
keys, left it in park and the handbrake on
I give up, back to doing the Falcon.
[Edited on 6/4/08 by Mr Whippy]
Danozeman
| posted on 6/4/08 at 02:40 PM |
Thought ud have learnt after the first one. Theyr utter shit. Cavaliers arnt too bad and the mk3 astras like t reg sort of thing but thats about it
Dan
adam1985
| posted on 6/4/08 at 03:26 PM |
cant argue with mine gsi had car couple of years now no real probs with her and a bit of a city sleeper
indykid
| posted on 6/4/08 at 04:03 PM |
my mk2 cav runs like a dream. 56k on an '87 E.
it's a bit thirsty on petrol but it has very few electric bits to go wrong
tom
thunderace
| posted on 6/4/08 at 05:48 PM |
its all the salt on the road take a quick look at any vectra from the south of england there like new after 5 years,this is a very common on the
vectra,seen it on all in scotland over 5 years old that are used in the scotish winter.(most cars look very bad after 3 winters in scotland )
motorbikes look very bad after 1 year winter use in scotland.(salt salt sail and water and cars and what do you get)
aerosam
| posted on 6/4/08 at 06:16 PM |
Can't believe it took you 4 of them to learn your lesson!
Simon
| posted on 6/4/08 at 06:30 PM |
My father bought bought a Vauxhall Victor in 1975. Most unreliable car he ever owned, so by the sounds of it, nothings changed.
The chap that bought it off him had it for 2 - 3 years and nothing went wrong
Simon
