joscorstjens
| posted on 14/4/08 at 11:53 PM |
wiper drive mechanics
I just installed my new wiper driver mechanism on my Cat. Can I just cut the flexible drive 'axle' at length or do I need to keep the
original length?
Mr Whippy
| posted on 15/4/08 at 07:48 AM |
poor cat...where does the wiper stick out?
if it's like the mechanism in the pic then yes you can shorten them, I have one in my Falcon. Make all the bends as shallow as possible or the
wiper speed will decrease. I also used oil instead of grease as the grease is too thick.
Bluemoon
| posted on 15/4/08 at 08:27 AM |
Yes cut to length.. Also don't use copper pipe as above pic, use the proper stuff from CBS etc..
Dan
Bob C
| posted on 15/4/08 at 09:38 AM |
to put a flare on the tube end - I stuck it in my lathe & pushed a big drill bit into the end (chuck in tailstock) with the lathe running
backwards
caber
| posted on 15/4/08 at 01:34 PM |
I chopped mine and used a brake pipe flaring tool, wasn't perfect but enough to hold in the wheelbox.
Caber
