Author: Subject: What do I have here??
Ivan
posted on 28/4/08 at 11:19 AM Reply With Quote
Opened my 3.9 Cortina diff to find this:
and this 180 deg around
wondered if I've stumbled across a limited slip diff as the spider housing is fully enclosed and not open on one side.
anybody know - can't check the normal way because I have the halfshafts out.
Mr Whippy
posted on 28/4/08 at 11:29 AM Reply With Quote
that's a bit odd, sure its not a solid one
Mr Whippy
posted on 28/4/08 at 11:39 AM Reply With Quote
I fail to see how you could cram all that into there...?! and slip diffs actually tend to be even bigger due to the extra clutch disk. do you do a lot of drag racing?
[Edited on 28/4/08 by Mr Whippy] Rescued attachment differential.jpg
minitici
posted on 28/4/08 at 01:34 PM Reply With Quote
Looks like a 'spool' type diff - i.e. solid!
Ivan
posted on 28/4/08 at 02:13 PM Reply With Quote
Hope it's not solid seem to recall that there was some differential movement between the shafts when I had them in - will put them in tomorrow and check - if they move differentially then can I assume it's "limited slip"?
[Edited on 28/4/08 by Ivan]
Mr Whippy
posted on 28/4/08 at 03:39 PM Reply With Quote
might be a limited slip one going by this -
http://www.currieenterprises.com/cestore/carriers.aspx
would love to see inside, think it's all loaded in from the other sided. Only way to be sure is to put the half shafts in and see if you can get a wheel to turn with the other stationary, if it does and it's heavy to turn then it's a limited slip one.
Ivan
posted on 30/4/08 at 02:08 PM Reply With Quote
Yep - put half-shafts in - definitely a LSD - think it's clutch type as per ^^^^.
I wonder what it came out of?
