Author: Subject: ZX9R clutch slip / new plates
rj
posted on 2/5/08 at 12:57 PM Reply With Quote
Got car taxed yesterday, took it out last night , and started getting serious clutch slip, Its already got uprated springs from TTS,fitted them last year and it sorted the problem, so thinking the plates now need replacing, they were on lower limit when I put the springs in. A search on here recomends oem plates, where is best i.e. cheapest place to get them ?
roadrunner
posted on 2/5/08 at 06:31 PM Reply With Quote
Just before you buy any new plates, just check the tension of your clutch cable, if it's just a tad over tight it will really slip.
rj
posted on 4/5/08 at 08:52 PM Reply With Quote
Many thanks roadrunner, yes cable was a bit tight, suspect nut may have ajusted itself ( very slack), thats the kind of locost fix I like !
