Author: Subject: Brake pipe rules
panichat
posted on 4/5/08 at 07:09 PM Reply With Quote
Brake pipe rules
Please can someone fill me in about the SVA rules regarding the flexible pipe from the chassis to the front caliper. Is there a prescribed route it has to take? Can it start above and behind the upper wishbones?
The reason for the question is I went to Stoneleigh today and had a look at other 7 type cars - most people's pipes originate in the area between the wishbones, mine is behind.
Dave
Dave
stuart_g
posted on 4/5/08 at 07:11 PM Reply With Quote
I don't think it matters as long as it doesn't foul anything lock to lock.
posted on 4/5/08 at 07:44 PM Reply With Quote
Stuart is correct - it mustn't foul anything. Also, it mustn't be stretched, kinked or excessively twisted from lock to lock, and it shouldn't rub against anything - especially the tyre!
posted on 5/5/08 at 05:54 AM Reply With Quote
If it's stainless steel braided flexi - it needs to be covered somehow as the braids are too sharp.
Our examiner picked up on this - fortunately we had ours built with transparent shrinkwrap on them. More to keep them clean than for this purpose... result!
panichat
posted on 5/5/08 at 07:33 AM Reply With Quote
Thanks for the responses.
Yes, they are stainless braided hoses so I'll have the think about how to cover them.
Dave
Bluemoon
posted on 5/5/08 at 07:51 AM Reply With Quote
You can use spiral wrap to cover (as used in wiring looms, you can get it from maplin)...
