locoR1
posted on 10/5/08 at 09:30 PM |
woohoo 0-60 4 seconds
Been out for a couple of runs tonight to set my E-Boost2 boost controller up!
Spent a wile running different boosts to get the settings needed to program the boost by rpm function.
Tired a few 0-60 runs using the digi-dash2 logger running 12psi boost before i mapped the rpm function i managed 4.5 seconds over 6-7 runs lots of
wheel spin in first on most of them but still a reasonable time.
The went home and reprogrammed it to gradually increase boost over the full rev range, before it started to build boost around 4k and made full boost
by 5k -5 1/2k not good for traction but entertaining to drive ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
woohoo its a different car to drive totally transformed it! I'm sure theres more to come with a bit more experimenting and practice on my part
but 2 two more runs an I'm down to 0-60 mph in 4 seconds although still with some wheel spin.
I'm more than happy with the times but what are other bec's managing am i suffering with to much power? is 4seconds a respectable time for
a bec turbo?
Dave...........
![](/galpreviews/cafe racer 1.jpg) ![Description](/gallery/cafe racer 1.jpg) Description
Check out my CB500T Cafe Racer build diary
posted on 10/5/08 at 09:34 PM |
Too much power?
Quite your jibba jabba you crazy fooool!
You can't have too many ponies
Congrats ![](/images//smilies/smile.gif)
Myke 2463
posted on 10/5/08 at 09:41 PM |
Hi Dave
Nice one, Ive Known you for over 5 years and your still not going to be satisfied as long as there is a challenge.
buy you a beer next time we meet.
Well done Mike
PS Ashley thinks your mad.
mookaloid
posted on 10/5/08 at 09:44 PM |
a bec turbo?
Dave...........
I would have thought you should be able to improve that - I was getting less than 4.5 sec from my Pinto Indy
Mark
zilspeed
posted on 10/5/08 at 09:47 PM |
Mark
Now there's a thought.
Some kind of change to the chassis which might allow the car to put the power down more effectively.
What tyres do you run ?
locoR1
posted on 10/5/08 at 09:54 PM |
Hi mike hows it going got that car finished yet? Mad me!!!!!![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Just to give you some idea what I'm preparing for"Linky"
locoR1
posted on 10/5/08 at 10:02 PM |
Mark
Spent all winter doing that changed from live axle to de-dion with 3.38 LSD
The winter mods were only finished last Friday then went to Stoneleigh for the weekend so had no time to properly set things up yet!
I'm running Toyo T1s tyres, got a set of Avon acd10's to try next!
zilspeed
posted on 10/5/08 at 10:05 PM |
I'd be wiling to bet that the ACB10s make quite a difference.
Then there's slicks after that of course
posted on 11/5/08 at 08:19 AM |
Lots of the 0-60 times that you see quoted on here must be taken with a pinch of salt.
Wadders is about the only person I know that has done a 0-60mph with proper timing gear.
Here are his results
Phil
hobbsy
posted on 11/5/08 at 08:34 AM |
I'd think 0-100 would be a more useful measure of your cars performance as doing a sub 4 second 0-60 is always tricky.
You'll definitely see an improvement if you run A048's/R888's or ACB10's.
Just watch you don't bust your gearbox doing all these 0-60 tests ![](/images//smilies/smile.gif)
amalyos
posted on 11/5/08 at 09:05 AM |
What cluch are you using?
I'm always worried about killing the clutch with too many hard starts.
http://stevembuild.blogspot.com
locoR1
posted on 11/5/08 at 09:42 AM |
I don't intend making a habit of doing 0-60 runs I've always been worried about the poor little clutch holding up, but so far so good
although you do have to let it cool down after a couple of runs! it a genuine Yamaha clutch doubled up on the clutch spring never slipped yet.
Helfire i totally agree with you on the timing! i was more interested in seeing what the boost controller could do to help traction of the line and i
think you would agree 1/2 a second is a lot on a 0-60 time especially being the first time I've used it!
0-100 now theres a thought! that should give more of an indication of its performance but what do i compare it with?
froggy
posted on 11/5/08 at 03:06 PM |
i go to curborough regularly and if i launch a bit more gently and dont spin it up in first it knocks over a second off my lap time and its worth 1/2
a second on my 1/4 mile time .ive got slicks now and they make a BIG difference![](/images//smilies/smile.gif)
mookaloid
posted on 12/5/08 at 01:52 PM |
Phil
Hi Phil,
Do you think my 0-60 should be taken with a pinch of salt?
Cheers Mark
Toady1
posted on 13/5/08 at 12:50 PM |
you should hit 100 very quickly! My old 954blade car kept up with a porsche gt3 on the straights to 110mph on a trackday I went to.![](/images//smilies/bigsmile.gif)
