garage19
posted on 29/5/08 at 04:02 PM |
KPI of cortina uprights?
Does anyone know the KPI of cortina uprights?
Has anyone actually measured it?
Mr Whippy
posted on 29/5/08 at 04:20 PM |
I thought we had cad drawings as a sticky somewhere, sure hubs are in there
Puk
posted on 29/5/08 at 06:01 PM |
CAD models:
Locost CAD linky
Before you judge a guy, walk a mile in his shoes. Then when you judge him, you're a mile a way and you've nicked his shoes.
Fred W B
posted on 29/5/08 at 07:21 PM |
A detailed drawing someone posted on here shows it as between 4 and 4.5 degrees
Cheers Fred W B
Mark Allanson
posted on 29/5/08 at 07:37 PM |
Nominal angle from Ford is 4°48', and surprisingly the applied castor is only 1°40' +-45'! - the weight must have a big bearing on
the self centring
andyd
posted on 29/5/08 at 07:57 PM |
This is from a bigger GIF I've got... 4 1/4 degrees if I read it correctly?
  Cortina upright
garage19
posted on 29/5/08 at 08:08 PM |
So not too bad then.
andyd
posted on 29/5/08 at 08:41 PM |
Depends on who you ask I think.
I've read that something around 10degs is optimal (Des Hamill's book) so that's what I'll be aiming for.
As I understand it though (and I don't profess to being anywhere near to knowing it all) you can compensate for the lack of KPI of the
'tina parts in some areas by adjusting other measurements.
