Metcalfe
| posted on 10/6/08 at 10:10 PM |
Handbrake Cable Layout
hi guys, is it possible someone could post some pictures or a description of how to layout the handbrake cable on a MK2 Escort axle.
Im not sure where to locate the thing..
cheers
twybrow
| posted on 10/6/08 at 10:23 PM |
I have twin cables (ditch the old escort bar arrangement). They cross over before passing over the top of the diff. They then run in a wide arc around
to brackets just inboard of the shock mounts. Clear as mud right?
DavidM
| posted on 10/6/08 at 11:26 PM |
Like this?
Proportion is Everything
| posted on 11/6/08 at 11:03 AM |
(1) You can roate and re-drill the back plates for more clearance
(2) Ditch the Escort cable & bar arrangement even on the Escort it didn't work properly. Either use twin cables or the complete cable from
a Morris Ital (nb Ital not Marina)
Metcalfe
| posted on 11/6/08 at 01:52 PM |
i see, can i get a pic of how it looks at the handbrake lever, and on the hubs?
great help lads, thanks
DavidM
| posted on 11/6/08 at 05:37 PM |
Handbrake end. I made a balance bar arrangement although you can't see it in the photo.
DavidM
| posted on 11/6/08 at 05:38 PM |
Hub end.
Metcalfe
| posted on 17/6/08 at 07:26 PM |
that handbrake set up picture is a great help, i dont suppose anyone has a picture of the rear hub with a disc conversion? the drums dont help me
much
cheers
Metcalfe
| posted on 24/6/08 at 08:24 PM |
any one got a picture of how the handbrake joins to a sierra disc hub?
