rumplitter
| posted on 18/6/08 at 01:48 PM |
made a template for my pedals
made a template for my pedals, have now cut a bit of 3mm plate to weld in, soon be able to bolt the brake and clutch pedals in.
I'll be attempting to make my own accelerator pedal.
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
Mr Whippy
| posted on 18/6/08 at 02:11 PM |
no matter how hard I look I cannot see any plate or template
rumplitter
| posted on 18/6/08 at 02:27 PM |
sorry it's not obvious!
I jacked up the plywood under the chassis and screwed the pedals into position. After several attempts i was happy with the positions.
I then drew round the whole thing in pencil and traced it off the plywood.
rumplitter
| posted on 18/6/08 at 02:29 PM |
accelerator pedal detail
Please see attached word document showing my proposed accelerator pedal.
Not sure what ratio you should have for 'A' or 'B' marked on drawing.
rumplitter
| posted on 18/6/08 at 02:32 PM |
duct tape steering column.
Please note that i will be strengthening the duct tape connections to the steering column.
I've only just extended the steering column with a sleeve, most things are currently held in place with ties/duct tape!
Mr Whippy
| posted on 18/6/08 at 02:33 PM |
ha I see, thank god cos I had a nagging doubt that wood for the floor
mr henderson
| posted on 18/6/08 at 04:32 PM |
What would be wrong with a plywod floor? As long as it was WBP and suitably sealed then plywood (preferably Birch plywood) has a very good strength to
weight ratio. 12mm ply would be about the same weight as 3mm aluminum.
John
