rumplitter
| posted on 23/6/08 at 04:08 PM |
floor mounted accelerator idea for approval
floor mounted accelerator idea for approval?
what do you think?
pivot at floor
accelerator at side front, return spring to rear
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
clairetoo
| posted on 23/6/08 at 04:16 PM |
Only possible problem I can see is that would be a 1 to 1 `ratio` ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
nasty-bob
| posted on 23/6/08 at 04:21 PM |
Howabout this..
Paul TigerB6
| posted on 23/6/08 at 05:11 PM |
Doesnt it really need to pull the cable rather than push??
nasty-bob
| posted on 23/6/08 at 06:34 PM |
his engine is in the back I believe, so will have the cable pointing backwards, up the side of the driver.
Rob
Ian D
| posted on 23/6/08 at 07:12 PM |
Try this.
paulf
| posted on 24/6/08 at 03:48 PM |
I find that the top hung pedal gives a better feel for the throttle pedal.The brake pedal is ok floor mounted as it has little travel, but accelerator
and clutch feel more natural when top hung.
Paul
