New Topic New Reply
Author: Subject: Radiator Fan Switch for 2.0L Pinto Indy
GH1985
posted on 1/7/08 at 04:56 PM Reply With Quote
Hi everyone, hope you are all enjoying the nice weather!
I've been searching on the forum about this and haven't had much luck. And I can't seem to find a telephone number for MK at the moment, as their website is not up and running yet.
So here I am... I've got one of the MK radiators and need a fan switch for it. I measured that it needed to be a M22 thread, and read it needed to be a pitch of 1.5, with a 2 pin electrical connection.
But does anybody know what temperatures would be suitable for a 2 litre pinto engine? I have bought one which will turn the fan on at 95 degrees and off at 85 degrees. Does this seem about right? I looked at the Haynes guide to see if it had any information, and then remembered it hasn't got a fan switch as it has one of those thermo-viscous fans.
Any help, guidance, or suggestions would be most appreciated and will help put my mind at rest - afterall I don't want to overheat my 'beautiful' Pinto engine
Thanks, Graham.
Oh just thought, the haynes guide said that the thermostat opens at between 85 and 89 degrees and has a nominal temperature rating of 88 degrees.
James
posted on 1/7/08 at 05:11 PM Reply With Quote
I used (I think) a Golf rad switch as it fitted my Golf (same as Polo but wider) rad.
There are several different switching temps for Golfs... I just went for the one closest to the Sierra's temps.
Make sure you choose the two pin, not the three.
James
GH1985
posted on 1/7/08 at 05:17 PM Reply With Quote
Thanks James, any more help with the temperatures will be greatly received!
James
posted on 1/7/08 at 05:33 PM Reply With Quote
I avoided posting the figures as couldn't remember!
But I'm 99% sure they're in the Haynes manual.
HTH,
James
EDIT: I should add, I've not driven the car with this rad/fan as I've only recently got it running. On a stationary test of 20-30minutes though it worked fine.
[Edited on 1/7/08 by James]
mad-butcher
posted on 1/7/08 at 05:46 PM Reply With Quote
I'd be quite happy with a range like that, better safe than sorry.
Tony
snapper
posted on 1/7/08 at 06:14 PM Reply With Quote
switches usually have an on and off temp aqbout 4 degs apart so on 88 degs and off 84 degs for the Pinto
I eat to survive
I drink to forget
LBMEFM
posted on 1/7/08 at 06:35 PM Reply With Quote
Vauxhall Cavalier rad switches are a perfect fit.
Barry
RobH
posted on 1/7/08 at 07:52 PM Reply With Quote
I think Snapper is right, but ring Burton they can tell you and supply the switch.
http://www.burtonpower.com/Default.aspx
Rob
martinq357
posted on 2/7/08 at 06:45 PM Reply With Quote
Graham,
I just brought one from GSF for the Polo rad but the thread is the same as the std. MK rad:
https://secure.gsfcarparts.com/shop/results.asp
I ended up with the 93470 near the bottom of the page. It was actually 88deg ON, 79deg OFF.
Regards
Martin.
New Topic New Reply
