saigonij
posted on 26/7/08 at 05:20 PM |
Finished My Dash today
All,
Today i managed to finish my dash.
I re-cut the dash from 9mm plywood as i wanted to ditch the Bright6 and replace with 12mm warning lights.
I then stuck and screwed a wooden batton to the back of the dash, and then to the dash and wooden batton, i glued and screwed some 19mm dowel from
B&Q giving me the correct radius.
I then covered with thin foam, and vinyl.
really pleased with the result.
Here are some pics...
![](/galpreviews/19mmRadiusOnLowerEdge.jpg) ![Description](/gallery/19mmRadiusOnLowerEdge.jpg) Description
![](/galpreviews/19mmRadiusOnLowerEdge_2.jpg) ![Description](/gallery/19mmRadiusOnLowerEdge_2.jpg) Description
![](/galpreviews/FinishedDash_1.jpg) ![Description](/gallery/FinishedDash_1.jpg) Description
![](/galpreviews/FinishedDash_2.jpg) ![Description](/gallery/FinishedDash_2.jpg) Description
![](/galpreviews/FinishedDash_3.jpg) ![Description](/gallery/FinishedDash_3.jpg) Description
![](/galpreviews/FinishedDash_4.jpg) ![Description](/gallery/FinishedDash_4.jpg) Description
last things i need to do are to velcro the carpets down, and fix the wing mirrors...
then im finished!
blakep82
posted on 26/7/08 at 05:25 PM |
oooh, very nice
________________________
adithorp
posted on 26/7/08 at 05:26 PM |
Is that dowel 19mm radius or 19mm diameter? It has the be 19mm radius(38mm Diameter) for SVA unless its padded.
adrian
saigonij
posted on 26/7/08 at 05:33 PM |
the dowel is 19mm radius. two quarter bits glued together to give 38mm diameter.
les g
posted on 26/7/08 at 05:51 PM |
very nice
and that looks like a set of etb clocks ????
les g
adithorp
posted on 26/7/08 at 06:03 PM |
10/10 for not making the schoolboy mistake then. I could't tell from the pictures.
Looks good.
adrian
posted on 26/7/08 at 06:07 PM |
Looking good ![](/images//smilies/smile.gif)
saigonij
posted on 26/7/08 at 06:38 PM |
smiths telemetrix clocks from westfield.
£380 delivered inc vat ( inc the senders )
speedyxjs
posted on 26/7/08 at 06:59 PM |
Oooh very nice
big_wasa
posted on 26/7/08 at 07:47 PM |
I just wondered why you didnt like the bright 6 ?
saigonij
posted on 26/7/08 at 08:06 PM |
my main problem was mounting it...
i did not want any screws showing , so it had to be back mounted, which caused issues - how do you mount it!
then, in the end, i just decided that i did not like the look of them - too small and too close together..
just my view of them. they are neat and compact, but just not for me.
