nathanharris1987
| posted on 30/7/08 at 09:05 AM |
Changing to LSD and rear discs
I'm thinking of upgrading the rear end and looking into the best way of doing it.
First of all with the brakes, im fully aware that you dont really "need" rear discs but they look rather coool.
At the moment ive got a normal diff (dont know what ratio yet) from the donor, push in shafts and drums. Correct me if im wrong but can you just
change the diff internals to have LSD or is it better to get a whole unit.
It has been suggested to search for an XR 4x4 and snap the rear axle etc off of that?
Anybody know of any suppliers or scrappies that deal alot with these?
Also will i need to alter my uprights or should it be a straight swap?
So many questions arghh!?!!
Mr Whippy
| posted on 30/7/08 at 09:24 AM |
pity I have a nice LSD but its bolt on
mcerd1
| posted on 30/7/08 at 10:00 AM |
wel you can't have the ford LSD with push-in shafts
and the rear bearing carriers are different - they have the mounting lugs for the calipers apart from anything else
but you could keep you current setup and fit something like a quaife ATB + a rear disc conversion - its not the cheap option
I think you can make some 'hybrid' driveshafts if you have ones with the right number of splines (push-in one end bolt-on the other), but
you'd still need a rear disc conversion
so the easy option would be the whole axle from something like an XR4x4 (or cossie 4x4)
what diff ratio would you like to have ?
there is always ebay (if you can find a rear end for sensible money)
[Edited on 30/7/08 by mcerd1]
nathanharris1987
| posted on 30/7/08 at 10:45 AM |
well, dont have to keep the shafts, im just looking for options innit!
so somthing like this maybe...
click
Mr Whippy
| posted on 30/7/08 at 11:16 AM |
click
I have the shafts too, boots look in good condition but the whole lot is quite heavy for postage.
| posted on 30/7/08 at 11:25 AM |
If you have a bike engine fitted, all you're gonna be doing is adding extra weight which will have a negative effect on your power/weight ratio
and you won't actually gain anything.
If however you have a car engine fitted, you're obviously not too concerned about bhp/tonne, so go for it.........
Phil
mcerd1
| posted on 30/7/08 at 11:51 AM |
although the axle is basicaly the same, problem with the cossie 4x4 setup is the vented rear discs
they'll add even more weight to the rear
I'd ask yourself if you really need an LSD ?
and if not just get yourself a rear disc conversion kit if thats what you want - all you'll need from a donor is a pair of calipers with slider
brackets (solid disc type)
and then a conversion kit (or a set of mounting brackets + pipes, cables, pads + discs to suit)
btw what size wheels have you got ? (i.e. make sure there are room for the discs )
| posted on 30/7/08 at 11:53 AM |
every time (Helfire)
IMHO the time, effort and money would be best spect on other things.
Have you had the car properly set up for corner weight, ride height, shock balance etc. If not then that's the best place to start - it will
make abg difference to the way the car goes, corners and stops.
[Edited on 30/7/08 by nick205]
mcerd1
| posted on 1/8/08 at 07:25 AM |
if you still want to do this - here you go:
http://www.locostbuilders.co.uk/viewthread.php?tid=94308
NTDWM
