Jonte
| posted on 30/7/08 at 06:37 PM |
Steering rack to hard/tight
At my SVA the man didn´t like that my steering was to hard/tight (heavy to steer).
How do I adjust that?
Its a 1988 Sierra steering rack as seen in the pic.
  steering rack
Click it
James
| posted on 30/7/08 at 06:47 PM |
If you jack the car front up does it turn ok? ie. is the rack ok?
If the rack is fine then it's just suspension settings and tyre pressures that you can adjust really.
A larger steering wheel will help, as will narrower front wheels/tyres.
Remind him it's not got power steering like his tin top!
James
- Muhammad Ali
| posted on 30/7/08 at 06:51 PM |
  steering rack
Could be a few things two most likely are.
(1) The rack damper has been adjusted up too much
or
(2) The rack is bent due to accident damage
After that you have too look at things like steering column problems --- the usinversal joints.
Jonte
| posted on 30/7/08 at 06:56 PM |
The rack is modified by MK but Ï´m not sure if it´s the one I sent to them to be modified that I got back.
Rack damper, where what is that
Maybe I give it some more toe in (1-2 degrees) and check the tyre pressure.
There is this old problem with self centering also....
Click it
skodaman
| posted on 30/7/08 at 07:03 PM |
Did he actually fail it on this?
Skodaman
Jon Ison
| posted on 30/7/08 at 07:07 PM |
Here, is it a quick rack, they tend to be a bit stiff especially with a small wheel.......
| posted on 30/7/08 at 07:22 PM |
Jack both front wheels clear of the ground and try turning the steering from full right to full left, it should require equal effort through all its
travel.
Ty the same by pull/pushing the road wheel.
If it tightens up more on one lock than the other it generally indicates a bent rack.
If it stiffens equally in both directions it could still be a bent rack but the rack may just be worn and over adjusted.
If the steering stiffens then becomes free then stiffens and becomes free then stiffens as the steering wheel is turned it indicates a steering column
universal joint problem.
As it is a modified rack it introduces the third likely possibility that the casing has been welded slight out of alignment.
The rack damper is called the slipper plug in the Haynes Sierra manual it not easily adjustable on the Sierra rack.
Kev99
| posted on 30/7/08 at 07:32 PM |
Check that Mk have not removed the roller bearing at the bottom of the input shaft they had on my quick rack . I had to rebuild it into my
other rack.
And it was over tight on the Rack damper as well since I redid these things the car self centers fairly well for a seven as well
| posted on 30/7/08 at 07:37 PM |
If it turns easily with the front jacked up then the tester was being a BGB....
Try pumping up the tyres good and high or fitting (temporarily) a bigger steering wheel....
| posted on 31/7/08 at 12:09 PM |
I'd recommend removing the rack completely and overhauling it as per the Haynes manual. You'd be surprised at how little force it actually
requires to operate correctly.
Once it's done, you should be able to operate the rack by turning the pinion with your hand.
Phil
