Author: Subject: Rear disc brakes
Pdlewis
posted on 2/8/08 at 09:11 PM Reply With Quote
Rear disc brakes
I have been going through the search and cant seem to find an answer to the following question.
what production car brake caliper disco combo can be used on an MNR? or am i stuck haveing to falk out for the rally design hydro machanical ones
Build Photo Album
Updated 05/02/2009
stuart_g
posted on 2/8/08 at 09:14 PM Reply With Quote
Sierra rear disc calipers and discs. If you have drum brake drive shafts/hubs then get adapter plates from MNR.
I think VW golf rears will fit aswell.
[Edited on 2/8/08 by stuart_g]
tomblyth
posted on 3/8/08 at 08:29 AM Reply With Quote
why not see what you can get then make them fit (alloy astra mk 5 calipers on modified sierra mounts on mine see photos!
[Edited on 3/8/08 by tomblyth]
COREdevelopments
posted on 3/8/08 at 10:56 AM Reply With Quote
im using toyota avensis calipers. my live axle is a corolla ae86 and it already came with cast calipers but they didnt clear the trailing arms, so managed to get avensis ones to fit easily enough. also muc lighter too!! as said above either use sierra ones or make some fit,
rob
