Author: Subject: Track Developments - Excellent!
charlierevell
posted on 4/8/08 at 05:43 PM Reply With Quote
Just a note to say how good track developments were on friday. Had my MK Indy booked in for a full suspession set up and its made soooo much difference to the car.
Couldnt believe the change on my first dry drive.
Corner weights are all done, toe and camber were out by quite a lot along with caster. Half day was bumped up to a full day due to some stuck nuts and fidly rear end!
However the fixed price still stood.
Couldnt recommend them more for anyone in the area around castle coombe and the south west!
Tango orange is an 'IN' colour!!
charlierevell
posted on 4/8/08 at 06:06 PM Reply With Quote
full price was £235 + Vat...
Jon Ison
posted on 4/8/08 at 06:45 PM Reply With Quote
Probably one of the best £250 you will ever spend on performance upgrades, bit like people changing carbs, chucking a cam in, waste of money if not set up properly afterwards.
charlierevell
posted on 4/8/08 at 06:57 PM Reply With Quote
I'd looked at all the engine mods, brakes seem adaquate for my driving on a 470kg car... Hence i went for the set up.
Next is the flatshifter to help gain confidence in the gear change!
procomp
posted on 4/8/08 at 07:49 PM Reply With Quote
Hi
yep probably the best £276 you can spend on a car is a full suspension setup. ( although you dont mention dampers being dynoed ) Makes a world of difference to the driving pleasure.
Cheers Matt
charlierevell
posted on 4/8/08 at 07:50 PM Reply With Quote
Didnt have dampers dynoed but do have the original print outs for that from the factory.
whitestu
posted on 4/8/08 at 07:56 PM Reply With Quote
I need to find somewhere near London to do the same.
Castle Coombe is a bit far!
Stu
procomp
posted on 4/8/08 at 08:38 PM Reply With Quote
Hi try THE RACE DOCTOR He travels to you with the full gear to do the setup.
Cheers Matt
whitestu
posted on 5/8/08 at 07:50 AM Reply With Quote
Thanks - I'll give them a call.
stu
