jacko
| posted on 4/8/08 at 07:56 PM |
Hand Brake cable
Hi a mate of mine would like to know what people are doing to modify there sierra brake cable ?
he Say's SVA say you can't cut the cable in the middle and clamp any more [ that's what i did ]
Its on a indy with disc rear brakes
thanks Jacko
eznfrank
| posted on 4/8/08 at 07:57 PM |
Oh bugger, that's what I've done! :-?
whitestu
| posted on 4/8/08 at 08:01 PM |
I'd heard the same so I cut the cable at the end and put a blob of weld on the end as a new nipple.
Its still fine after 2 years.
Stu
[Edited on 4/8/08 by whitestu]
stuart_g
| posted on 4/8/08 at 08:19 PM |
Here's my effort. I cut the handbrake cable in half. I then used the adjuster off a rover 200 handbrake and bolted this to the Sierra lever. The
cable is attached to the adjuster with a piece of 10mm rod drilled through so the cable will go through then drilled from top to bottom and tapped to
4mm. Cable is securd by a grub screw top and bottom.
Adjustment is done through a hole in the rear bulkhead panel and a rubber grommet seals the hole after adjustment. Works a treat.
Nosbod
| posted on 4/8/08 at 08:32 PM |
I've also cut mine in the middle ... doh ! but, how can they check short of removing panels from the tunnel?
| posted on 4/8/08 at 09:00 PM |
I cut it and it was no problems 18 months ago.... What's wrong with wire clamps???
jacko
| posted on 4/8/08 at 09:06 PM |
When i had my sva about 4 years ago the sva man had a good look down the tunnel from the diff end
Ben i don't know what's wrong with clamps thieve been ok on my car for 4 years but things change as time goes on
Graham
repper
| posted on 4/8/08 at 09:16 PM |
i heard if you rap it round so you cant see the clamps or wear its been cut thar are not allowed to remove the rapping to see how its been modded
there for thay have to pas it ???
Stuart_B
| posted on 5/8/08 at 09:22 AM |
i cut mine at one end and then resoildered the nipple of the hand brake cable back on.
stuart
