Author: Subject: Alternative gearshift Pivots??
charlierevell
posted on 5/8/08 at 06:38 PM Reply With Quote
What have people done instead of using the following?
[img]http://www.locostbuilders.co.uk/viewthread.php?action=attachment&tid=85642&pid=714544[/img]
Mine has up down play in and i'd like to make it better until i get the paddle shift made up!
Photos would be great, and id like something i can create at home with little/no welding as i cant do that easily!
Thanks... Charlie
[Edited on 5/8/08 by charlierevell]
Tango orange is an 'IN' colour!!
novacaine
posted on 5/8/08 at 07:05 PM Reply With Quote
Picture inserted and resized
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
charlierevell
posted on 5/8/08 at 07:08 PM Reply With Quote
Well done, was just doing that and then it kicked me off! flippin thing!
Thanks tho!
charlierevell
posted on 6/8/08 at 10:48 AM Reply With Quote
No1 got any pictures??
adithorp
posted on 6/8/08 at 12:17 PM Reply With Quote
Here's mine if its any use to you. Its conected to my paddle shift and works well.
http://i189.photobucket.com/albums/z282/adrianthorp/Picture034-1.jpg
The gearbox lever on yours looks like it might be a bit thin and the joint is a long way out from it which could be giving quite a bit of flex/twist.
adrian
http://jpsc.org.uk/forum/
charlierevell
posted on 6/8/08 at 12:30 PM Reply With Quote
The above isnt mine... its just the same main pivot design. My gearbox mount is the original i think!
