Author: Subject: Dax Paddle Shift
charlierevell
posted on 12/8/08 at 10:32 AM Reply With Quote
Dax Paddle Shift
Has anyone tried this out? Has anyone used it on something other than the dax?
Im interested in using the design as a base for mine but not sure how to mount it under the sierra column, what to use for the pivot etc...
If i could use the 'horns' id buy it and try it but i think they'll be huuuuge on a 270mm wheel!
Any other thoughts?
Tango orange is an 'IN' colour!!
INDY BIRD
posted on 12/8/08 at 10:40 AM Reply With Quote
I used this years ago
System was excellent used in 2 mk indy's
Never missed a gear and some pics attached for you,
INDY BIRD
INDY BIRD
posted on 12/8/08 at 10:41 AM Reply With Quote
charlierevell
posted on 12/8/08 at 10:44 AM Reply With Quote
How wide are the paddles?
Did all the linkage bits come with it or did you make that up...?
INDY BIRD
posted on 12/8/08 at 10:50 AM Reply With Quote
No the links you can get from dax and the mounting bracket to the column, i just purchase some length of m8 rod from b&q to attach to either end of the ball joints,
I used the original gear linkage mk supply and mounted it at the top as you can see from pics,
its a mountey 12" wheel i dont have the car anymore but the widest point is 12"
Hope this helps
Sean
charlierevell
posted on 12/8/08 at 11:41 AM Reply With Quote
I think my MK pivot has died.... i can twist the top without the bottom moving!
INDY BIRD
posted on 12/8/08 at 01:10 PM Reply With Quote
Prob just needs welding back up,
If not get mk to make a new one for you,
Only a coulple of pounds,
Sean
