Kosmo
posted on 16/8/08 at 03:21 PM |
R1 (5VY 2005) engine cuts out when put in gear ?
Just started to do my gearshift system and when testing and putting into gear the engine cuts out ?
To start the engine again I have to put in neutral, anyone got any ideas ?
Kosmo
[Edited on 16/8/08 by Kosmo]
Omni
posted on 16/8/08 at 03:23 PM |
Sounds like the side stand trip switch to me (which kills the engine when put into gear if the side stand is down). Is the trip switch still in the
loom?
O
trottski
Possibly something to do with the stand switch?
Stott
Sorry I can't be specific with the whereabouts of it but your problem is the sidestand inhibitor switch which is designed to stop you pulling
off with the stand down (on a bike)
You need to short, or open that pair of contacts on the loom and your away,
Stott
Omni
posted on 16/8/08 at 03:25 PM |
HAHA! I was first
O
[Edited on 16/8/08 by Omni]
Stott
This site is great! 3 good answers all at the same exact time, lol ^^^^
Kosmo
posted on 16/8/08 at 03:38 PM |
Wow, that was quick !
I thought I had done this but I will go and check, Is this the Blue wire with black stripe from cut off relay and should it be link to -ve ?
Kosmo
Kosmo
posted on 16/8/08 at 05:13 PM |
New problem ?
Linked side stand and clutch switch and it now stays running when you put it in gear.... however now when I switch the ignition on the fuel pump runs
continuously where before it used to run for about 3-5 seconds then stop until the engine is started ?
Is this normal ?
Kosmo
posted on 20/8/08 at 01:44 PM |
Just fixed this problem.... all my wiring was originally OK, thats a relief, anyway, problem was cut off relay, replaced this and all works as it
should.
Thanks for all the advice,
Kosmo.
