macspeedy
posted on 30/12/03 at 02:50 PM |
Protec vx spax
I am just about to buy a set of shocks and i am torn between the spax and the damper tech ones what would i get for spending £50 more on the damper
tech ones?
dozracing
posted on 30/12/03 at 03:20 PM |
I think you may be mistaken somewhere along the line.
Protec are offered by MK
GAZ by Damper Tech
Spax by Everyonee.
GAZ and Spax internally are very similar, using many of the same parts, and as such you will get the same performance which ever one you buy so go for
the cheapest.
The Protec is a better shock, and offers internals that are at least different to the others, and have a better adjuster system.
Kind regards,
Darren
macspeedy
posted on 30/12/03 at 05:23 PM |
what was i saying????
you are totaly right its a case of x-mass head up arse!
The question should read What benifits are there with buying the protech dampers at £300 from MK as apposed to buying gaz shocks at £250 from
Dampertech?
(answer is probably going to be nothing?)
mangogroove
posted on 30/12/03 at 05:33 PM |
the answer is £50
Fifty Quid macspeedy If you want to look at them give me a shout
macspeedy
posted on 30/12/03 at 09:47 PM |
if you are passing Edinburgh before next Tues that would be great!
dozracing
posted on 1/1/04 at 12:57 PM |
The protechs are lighter, less likely to rust and jam up, the adjustment mechanism is more reliable and very worth the extra £50.
Kind regards,
Darren
