blakep82
posted on 26/8/08 at 07:14 PM |
hand brake questions. mechanical? electric? other?
is there any rules on which side of the driver seat the lever has to be on? i don't think so, but want to be double sure. as long as it can be
reached/operated i think
has anyone on here managed to do some kind of electric hand brake yet? i'd like one, i haven't got anywhere on my pickup to mount a normal
lever, the tunnels not strong enough. the seat mounts is the only place, but its tight for the seat already anyway.
a simple push button job would be nice, but i don't really get how they work
[Edited on 26/8/08 by blakep82]
________________________
flak monkey
posted on 26/8/08 at 07:34 PM |
No rules on where handbrake need to be, but should be easily operable from the driving position so i was told at SVA.
So how some people get away with them under the passenger side of the dash is beyond me...
Sera
http://www.motosera.com
yamapinto
posted on 26/8/08 at 08:26 PM |
Electric handbrake
I have fitted an electric handbrake to my mk it is made from a sunroof motor that turns through a bevel gear set up that operates a screw thread to
pull the handbrake cable all operated by a dash mounted toggle switch and it fits in the mk transmition tunnel.
blakep82
posted on 26/8/08 at 08:31 PM |
have you sva'd yours yet/with it fitted?
I'm not entirely convinced electric ones are any more reliable than say a hydraulic line lock, but i see electric ones on production cars, so
would be quite good.
yamapinto
posted on 26/8/08 at 08:40 PM |
I sva'd the car a long time ago but it has been through an mot the way its made once applied it cannot come off even if the power is cut this
gets round the rule of it failing over time if left on (that is the problem with hydrolic ones) it is also only opporational with the imobaliser chip
and ignition key in (to stop idiots turning the handbrake off for fun)
omega 24 v6
posted on 26/8/08 at 08:44 PM |
hydraulic line lock
Sva fail that one. It has to be a mechanical type handbrake i.e. separate from the hydraulic lines. Electric should be OK but don't quote me![](/images//smilies/bigsmile.gif)
blakep82
posted on 26/8/08 at 08:45 PM |
ah, sounds perfect! is it one you made yourself, or can it be bought anywhere?
blakep82
posted on 26/8/08 at 08:47 PM |
quote: Originally posted by omega 24 v6
hydraulic line lock
ooh i know thats a fail i was thinking though, with electric motors pulling cables and holding them, i was thinking the motor could turn over time
and release. i guess though it it turns a grub screw type gear it can't release... hmmm
martyn_16v
posted on 26/8/08 at 08:49 PM |
My van (Scudo ) has it on the 'wrong' side between the seat and the door. I seem to remember Porsche putting it there on the 924 as
well.
yamapinto
posted on 26/8/08 at 08:53 PM |
its one i made myself its actualy a worm wheel turning a bevel gear screwing a screw thread pulling the brake cable
it sounds complicated but it isnt realy it gives an amazing pulling power and cannot unscrew itself the reduction gearing is too great
blakep82
posted on 26/8/08 at 08:58 PM |
not bad
think its one for each wheel, but a lot cheaper than i'd expected
les g
posted on 26/8/08 at 09:36 PM |
hi blake
sometimes the cable is pulled by a spring and the electric motor works against the the spring to release the brake
ie ..in acomplete fail of every thing electrical the park brake still holds
hth
les g
mangogrooveworkshop
posted on 26/8/08 at 10:40 PM |
blake look at the hilux hand brake
blakep82
posted on 26/8/08 at 11:21 PM |
had a search but i couldn't find any info on the hilux... i did see somewhere something about a rheostat, its like a variable resistor to
control it? sounds good. though i do like the idea of just a toggle swith, or push buttons, but something a bitmore variable would be cool
yamapinto
posted on 17/9/08 at 11:18 AM |
quote: Originally posted by les g
hi blake
hth
les g
That sounds a bit iff'y what if it came on while you were driving down the road?
I'd rather it fail whilst parked or not be able to get the handbrake than for it to come on when least suspecting it.
