Author: Subject: Driveshaft question
Ahdammit
posted on 27/8/08 at 09:30 PM Reply With Quote
Driveshaft question
Hi guys
a car I'm working on has rotoflex couplings and u'j's on the driveshafts.
I'd like to do away with the rotoflex's and fit cv joints instead.
Would the u/j and cv joint combination work ok or is it a bad practice?I cant recall ever seeing this combination before,so I dont know if they're compatible.
Any advice?
John
[Edited on 27/8/08 by Ahdammit]
mark chandler
posted on 28/8/08 at 06:37 AM Reply With Quote
They do work, SD1 rovers had CV joint on engine side of the propshaft and UJ at axle end.
Dingz
posted on 28/8/08 at 12:34 PM Reply With Quote
The rotoflex allow some change in length of the driveshafts as the suspension moves, cheaper than having splined sliding shafts. If you make it solid there may be no suspension
Ahdammit
posted on 29/8/08 at 08:25 PM Reply With Quote
Thanks for the replies guys.Dont cv joints also allow changes of length?Surely they must?
