finlay
| posted on 30/8/08 at 07:48 AM |
how do i remove sierra steering wheel ?
hi all
i am about to fit my MNR supplied quick release OMP steering wheel but cant see any obvious way of removing the sierra steering wheel,
how do i remove the sierra and fit the omp ?
this is the type i have
any help would be appriciated
cheers
Finlay
tegwin
| posted on 30/8/08 at 07:58 AM |
You need to lever out the horn in the center of the wheel....
A big screwdriver and a hammer will do if you dont want to re-use the wheel....
Then undo the big nut and remove the washer....
Hit the wheel from behind with a hammer/brick to pop it off the taper...
Jobs a goodun!
www.verticalhorizonsmedia.tv
jollygreengiant
| posted on 30/8/08 at 08:24 AM |
AND make sure that the key is in the ignition so that the steering lock is dis engaged as that also locks into the back of the steering wheel.
Cousin Cleotis
| posted on 30/8/08 at 08:36 AM |
If you are sitting in the drivers seat and pulling on the steering wheel, leave the nut on a couple of turns so when it does pop off you dont hit
yourself in the face with it.
Putting you knees under the bottom and pulling on the top, move it side to side a little, 9/10 you wont have to hit it.
Paul
novacaine
| posted on 30/8/08 at 11:42 AM |
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
Macbeast
| posted on 30/8/08 at 04:19 PM |
Don't throw it away - ppl in here sometimes ask for the OEM wheel for SVA purposes.
