marshall
posted on 31/8/08 at 08:11 PM |
vvc?
anyone know what book is best to help me with the engine it is a 1.8i vvc 1996 .
as there is a spark plug that was put in x freded but not buy me. so i need to take the cylinder head and remove it. please help...
mookaloid
posted on 31/8/08 at 08:37 PM |
Have you tried a haynes manual?
les g
posted on 31/8/08 at 09:08 PM |
hi marshall
you could heli-coil the thread rather than take the head off
diy its quite easy or your local machine shop will do it
cheers les g
posted on 31/8/08 at 09:59 PM |
Is the thread stripped or just crossed ? if just crossed just run a chaser down it 90% of the time that will save the day -- with a 3/4" reach
plug you generally have more than enough thread left to hold the plug in.
http://www.agriemach.com/product_info.php?products_id=578
If that won't work --
Personally I would try a helicoil or other insert insitu and grease the tap well and use compressed air to clear out the swarf,
http://www.agriemach.com/product_info.php?cPath=0_64&products_id=722
However if you want to lift the head get yourself a copy of Rover RAVE CD manual (usually loads on ebay) and study it BEFORE stripping anything ---
these engines don't take to being torn down unless first the timing marks have to be lined and the bolts undone in the correct order.
[Edited on 31/8/08 by britishtrident]
