archspeed
| posted on 3/9/08 at 02:18 PM |
Brake Light Microswitch on Brake Pedal !
Hi All,
Rather that me trying to re-invent the wheel Does anyone have a picture of a switch / microswitch actually fitted to the brake pedal assembly to
operate the brake lights?
I'm wanting to have a switch on the pedal rather than messing around with a hydraulic switch in the brake line itself. Also I gather the
hydraulic switches arent very sensitive - so seeing as I have had someone hit me up the chuff before WITH brake lights on (in a tin top)- I'm
leaning in favour of a microswitch to ensure the lights come on at the slightest touch of the pedal!!
I've searched the forum ( as it usually answers my questions!) but whilst there several posts were people have done it, I cant find any
pictures!!
Thanks for any help
Kevin
PS - If it matters car is an MK Indy. ( With Floor Mounted Pedals)
[Edited on 3/9/08 by archspeed]
Paul TigerB6
| posted on 3/9/08 at 02:27 PM |
I got one from Maplin Electronics for a few quid and made a simple bracket to fit the switch to the front of the pedal in the depressed position so
that as the pedal was pushed, the switch was released. There are generally 3 terminals on the sitched to allow it to be wired accordingly.
No pic sorry.
From memory, this was the one I used here with the roller and is rated at 12A /
250V AC
[Edited on 3/9/08 by Paul TigerB6]
| posted on 3/9/08 at 02:31 PM |
The 3.5 amp current is a bit high for a lot of microswitches however you could use either a tin top pedal stop switch or the older pull switches used
on old cars and motorcyles.
http://www.completeautomobilist.com/parts/auto%20electrical/switch/
Be aware that pedal mounted switches need to be carefully set up.
welderman
| posted on 3/9/08 at 02:38 PM |
Maplin part number is GW73Q
Thank's, Joe
I don't stalk people
welderman
| posted on 3/9/08 at 02:42 PM |
http://www.locostbuilders.co.uk/upload/brake_switch.jpg
Thank's, Joe
archspeed
| posted on 3/9/08 at 03:00 PM |
Hi again
Thanks for the help so far with switches, I'm still a bit confused as to how to actually mount the switch, Paul Tigerb6 suggested mounting at
the front of the pedal - but wouldn't this be easy to catch with your foot and bend out of shape??
Sorry if i'm being dumb!
Kevin
Paul TigerB6
| posted on 3/9/08 at 03:05 PM |
quote: Originally posted by archspeed
Hi again
Kevin
Mine was way up out of the way on top mounted pedals. What sort of pedals are you using??
| posted on 3/9/08 at 03:06 PM |
Good pla re the sprung switch.
I always worry about a micro switch being "kicked" out of the way so it doesn't work. Hydraulic switches need a little gusto but
there don't go wrong that often.... Hydraulic switches work better if the the switch is below the rest of the brake circuit, most people use a
T-piece pointing upwards so you get a little air bubble under the switch. Doesn't help the switch work well and can introduce a spongy pedal
feel.
archspeed
| posted on 3/9/08 at 03:10 PM |
Hi again
Kevin
That makes sense!! My pedals are floor mounted So I cant mount a switch up in the top area, ( I should have mentioned that bit - Sorry)
Kevin
RK
Yes, good question. My idea was to mount it behind the pedal (top mount pedal box) on a steel or thick ally bracket rivetted to the chassis. Too thin
an ally and it will move.
I will post pics once I've got it done. Need to bleed brakes tonight before I get going on switches. Haven't been able to coerce the
missus to come and help... something about our 20th anniversary that takes precedence. No priorities.
[Edited on 3/9/08 by RK]
will121
| posted on 3/9/08 at 03:22 PM |
may be the easiest way is to get in the foot well of your tin top assuming you have one, and have a look how that is fitted as most standard cars work
or did work by mico switches bolted to the back of the pedal box and press against/above the pivot point
James
| posted on 3/9/08 at 03:39 PM |
In got one with my Nissan Micra pedal set... but when I made my own pedals instead I binned it in favour of a mechanical one. I really don't
like the idea of the switch in some way jamming the brake pedal!
If someone hit you when you had the brake lights on anyway... why is that a reason not to have mechanical.
Mine's from VW for a MK2 Golf... it's hardly going to be unreliable! Just screws into a 'T' piece at the rear.
If you're worried about people driving into the back then fit a high level brake light to the roll bar. Premier Wiring do a nice LED one.
HTH,
James
[Edited on 3/9/08 by James]
- Muhammad Ali
archspeed
| posted on 3/9/08 at 03:40 PM |
Sorry - but I forgot to mention my pedals are floor mounted!
nib1980
| posted on 3/9/08 at 03:47 PM |
why not just use a sensor in the Brake fluid line like everyone else?
Paul TigerB6
| posted on 3/9/08 at 03:56 PM |
Given the difficulties you will face in trying to fit a microswitch to floor mounted pedals in such a way as to take away any risk of kicking them
then i'd have to agree a hydraulic switch would be the safer option. No matter what sort of switch you fit, there is no accounting for the
idiots on the road who drive too close.
The above idea of fitting an LED strip (underside of the roll bar) is a good one for that extra visibilty. If you are concerned about the longevity of
hydraulic switches then why not plumb in a second hydraulic switch to operate the 3rd brake light?
archspeed
| posted on 3/9/08 at 04:19 PM |
I was a bit worried about using a hydraulic switch as reading through posts done in the past, many people seem to be of the opinion that they are not
very sensitive, so only come on when a fair amount of pressure is applied to the pedal.
I would feel much better knowing the lights are on as soon as I even touch the pedal.
Having said that, It does seem to be the general opinion is a hydraulic switch - so I may have to re-consider...
RoadkillUK
| posted on 3/9/08 at 06:01 PM |
I've never actually looked, but my Xantia has a pedal mounted brake light switch.
Can't seem to find anything about it online though.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
DarrenW
| posted on 3/9/08 at 06:46 PM |
For those that have hydraulic switch that doesnt work too well - ive been told that series 2 landrovers used the lighter sprung switch and is an
effective mod.
RichardK
| posted on 3/9/08 at 07:20 PM |
This is how I did it, but as I made these from scratch may not help you that much.
Rich
Gallery updated 11/01/2011
Ian D
| posted on 3/9/08 at 07:28 PM |
Try this my hydraulic switch which works well mounted on the end of the brake balance regulator using a t piece.
Keeps it out of the foot well and is easily accessible.
Ian
| posted on 3/9/08 at 08:08 PM |
I still think there's a market for an accelerometer based brake switch so that engine braking alone would light up the brake lights.
Only trouble is I think it would fail MOT..... which seems a shame really as it would mean the light comes on when you're braking yet you
don't burn the retinas of the person behind you out when sat in traffic on an incline....
Canada EH!
| posted on 3/9/08 at 08:30 PM |
When I was a kid, there was a very popular addon, a small traffic light in the rear window of tintops. worked off engine vacuum, foot on the gas-green
light, lift foot to coast-amber light, lift foot off the accelerator-red light. today we could probably do it with onboard computers.
archspeed
| posted on 5/9/08 at 03:18 PM |
Thanks to all that have replied...
For anyone thats interested, this is about the best way I've found to mount a brake light switch on floor mounted pedals....
I think I will use a heavier duty switch, and tidy the wires up a little more....
[img][/img]
