Author: Subject: Ral Des Steering Column Support?
BigDawgV8
posted on 3/9/08 at 08:05 PM Reply With Quote
Has anyone come up with a way of supporting the steering short-shaft?
My uj's and short-shaft came from Rally Design.
I'm thinking either a pair of nylon blocks clamped together with the shaft in between or some sort of bearing?
All ideas appreciated.
Martin
blakep82
posted on 3/9/08 at 08:13 PM Reply With Quote
what diameter is the shaft? and could you take it apart to slide a bearing over the end?
what about a huge rose joint (cheap one from billy mcGill on ebay) as used on legends racing cars?
________________________
chris_smith
posted on 3/9/08 at 08:18 PM Reply With Quote
how about something like......
Mix
posted on 4/9/08 at 04:04 PM Reply With Quote
Hi
Are you sure it requires supporting?
Regards Mick
MikeR
posted on 6/9/08 at 06:13 PM Reply With Quote
depends what you're trying to do.
I have an extra uj in my steering rack, therefore it needs support. Thought about it for a while (perhaps a year or two) and bought a roll bar clamp the right size. They're designed to have something twist inside them and clamp together so would fit easily. Job done.
BigDawgV8
posted on 7/9/08 at 08:06 PM Reply With Quote
Thanks for all the replies!
Where did you get your clamp from?
