Author: Subject: remote brake bias adjuster?
rumplitter
posted on 8/9/08 at 11:25 AM Reply With Quote
I got a remote brake bias adjuster with my Wilwood brake, I know the theory of how it works but just can't see it. It just seems to move the bar along, not changing angles on the bias bar. Am I missing something? Yours, confused!
Also concerned that the cable may get in the way of my floor mounted accelerator pedal!
http://www.locostbuilders.co.uk/upload/MiniMojoProject.JPG
will121
posted on 8/9/08 at 11:33 AM Reply With Quote
dont think in its static position (dependant on same push rod adjustment lenght) you will see a change in angle, the adjustment just moves the leaverage point so when the peddel is depressed hard you shoud get more force applied to one cylinder more than the other and then the angle of the bar changes.
for a bit more reading see
http://www.rallydesign.co.uk/balancebar.php
[Edited on 8/9/08 by will121]
Humbug
posted on 8/9/08 at 12:55 PM Reply With Quote
What the Rally Design diagram doesn't show (assuming it is in fact the same as mine) is that threaded bias bar has a central pivot thingy fixed to it. When you wind the bar left or right, the position of the pivot moves inside the bush between the pedals. This, in combination with having different diameter master cylinders for front and back, means that one cylinder gets pushed in more than the other; winding the bar either way adjust how much the difference is.
Mix
posted on 9/9/08 at 04:00 PM Reply With Quote
Hi
What Hubug said ^^^, the adjuster moves the balance bar bearing within the tube thus altering the pivot point and hence the moment arms to the two master cylinders.
Regards Mick
